Question about Bosch KTR18424 Compact Refrigerator
Bosch KTR18424 Compact Refrigerator completely dead no display either fuse in plug ok
    President:
  • 1,891 Answers
Ok unit is dead . ck the power at the plug first . if ok then look for a bad connection to ref .. there is no fuse in the unit to prevent it from working . some times they do get stuck in defrost cycles and is so repl the A D C .. hope this helped mm.
Posted on Jul 22, 2010
Why is Display not turning on
take out the plug
check fuse
check the wires to the board from the plug not broken
the board may be blown?
Aug 17, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
Dometic cr-50 refrigerator stopped working
check outlet power on back if ok check fuse if ok check 12 volts at power board
Mar 08, 2013 | Dometic Refrigerators
Not getting cold
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 21, 2011 | Bosch KTR18424 Compact Refrigerator
I have a Bosch wkm 41 maxx classic front loader that is completely dead. Got home from a camp trip yesterday, did two loads, and then wouldn't do a third. No lights, no sounds, completely dead. Any...
Hi Simon from retired Englishman in SW France,
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 25, 2011 | Washing Machines
I need a new door seal
Im afraid without the model number, which is located inside or outside on the back of your refrigerator, unless the model number tag/sticker/plate was removed or is not readable, finding the correct part would be extremely difficult.
Jun 28, 2010 | Bosch KUL1444 Compact Refrigerator
Kenmore 546033 Side by side Control/Display panel dead
yes the only way is to repl the control board and make sure your outlet is properly grounded but you might wan t to unplug and plug it back to see if it resets but still it has to be repl ok
Jan 17, 2009 | Kenmore 54603 / 54606 Side by Side...
Completely Dead
there is a fuse in the top right hand of the microwave it will burn out when the Capacitor goes bad it will burn it out replace the Capacitor diod and fuse
Jan 05, 2008 | Thermador MBBS Microwave Oven
Fridge door
Did you ever get any advice for this problem? Please repost if not.
Nov 10, 2006 | Bosch KTR18424 Compact Refrigerator
Bosch KTR18424 Compact Refrigerator Logo
168 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
