Question about Maytag Refrigerators
My Maytag refrigerator Model PTB1954GR is not cooling. It has power, internal lights are on and I can hear a noise like a fan spinning as though it was working normally. However, besides the fact that is not cooling, and I can hear a click every now and then. Any suggestions?
Hello. Well I couldn't wait too long for an answer so I had to call in the technician and gave me the final veredict........ The compressor was dead, so not worth repairing.
Solution: Bought a new fridge....Anyhow, Thanks for your help!
Posted on Apr 24, 2008
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Maytag refrigerator model msd2651heb not cooling. Hear fan running but not condensor
if you mean the compressor isn't running most likely you have a bad start device part 67005560,pull out machine unplug it and remove the bottom back panel,look at compressor,pop off metal clip and remove cover on the side of compressor,slide off the device and shake it,if the device is cooked you'll hear pieces rattling around inside it,install new part,if it still doesn't start could have a bad compressor.
Jul 14, 2012 | Refrigerators
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
Water is dripping from bottom of freezer into refrigerator area
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Maytag PTB1954GR Top Freezer Refrigerator
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
Fan clatter
Check the fan motor mounting screws in the back, they may be loose. The fan motor is located behind a removable panel in the back. Also with the power off spin the fan blade and look to see if one is bent a little. While you are at it clean the condenser area.
May 28, 2008 | Maytag MSD2756G Side by Side Refrigerator
Maytag Refrigerator
Usually when this happens it can be a couple of things. Push on the back wall of the freezer and see if you hear a crunching noise like walking on snow. If so then you have a defrost issue that isn't allowing the evap fan motor to push the cold air into the fresh food compartment. If not, push the door switch so the light goes out, now you should hear a fan running, if not then the evap motor has failed. If both of these are good, remove the toe kick and clean the lint and such out from under the refrigerator. This can cause the condenser to run hot and not cool properly. You should also feel air movement down there as well. Hope this helps.
Feb 04, 2008 | Maytag MSD2754G Side by Side Refrigerator
Refrigerators Logo
102 people viewed this question
Top Maytag Refrigerators Experts
isaac johny
isaac johny
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
