Question about Samsung LN-S3251D 32 in. LCD HDTV
No Picture and Sound on my new LE32B450
I have a new Samsung LE32B450 TV. When the power cable is plugged in, the TV makes a starting sound, but the picture appears only for 1-2 seconds, and then goes off. I can not set the TV because there is nothing on the screen. What is the problem? and how can i fix it ???
SOURCE: Samsung LTN1765 has blinking green power indicator, but no picture or sound
Try replacing C51, a 10 microfarad 16v. surface mount electrolytic. It's near IC23 on the upper center of the board.
This part had high ESR on a couple of sets I serviced which
kept the power supply from starting.
Posted on May 10, 2008
SOURCE: Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Posted on Jan 28, 2009
  • 98 Answers
SOURCE: Samsung LNR408DX/XAA Powers on with sound but no picture
I think you need to exchange the Main Board.
Posted on Feb 06, 2009
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Posted on Feb 08, 2009
javswr
  • 44 Answers
SOURCE: Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Posted on Feb 28, 2009
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
Samsung Plasma TV has standby power but no video
Make sure your video and sound cable is working (rca, hdmi cable etc) and your source component like dvd player or settop box is working. If cable is plug into a socket AV 3 or HDMI 3 for e. g. make sure the tv is source or input is selected the same like AV 3 etc.
It is possible for the TV to switch on or off but no picture or sound. This means the input board or tv tuner is faulty in which case you need a good tv repair technician
Oct 26, 2015 | Samsung PN43E450A1FXZA PN43E450 43 720p...
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
How to make my My SAMSUNG Le32b450 turn on?
if total dead (nothing) follow the cord inside the set (note that some models have a master on/off on the rear of the set) to the line fuse that it goes almost directly to.
Next step if able to is inspect the power board for signs of damage including burnt parts or puffy filter caps.
Then the real way is to measure voltages into the power supply and out of it--some people are not able to do this--if that is you consider having a tech or shop look at the set and get an estimate.
Dec 21, 2012 | Samsung LE32B450 32 in. LCD TV
SAMSUNG Le32b450 DOESN'T TURN ON
check or have checked the power supply in this set, if not able to do it yourself have a tech or a shop examine it.
TV showing picture but no sound
Could be the cable box is bad,u should check all other tvs in the house are find,if it have sound? Yes,tries unplug the tv and the cable box about an hour.Replug both back in.Let the cable box upgrade it software.The tv it now resetting back to it factory setting.Go into the tv Menu,go to AUDIO setting,go down to reset the AUDIO setting back to factory setting.The tv should have sound now.Not,than the Tuner board is dead,that the board take in the tv broscasting cable signal plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Aug 02, 2010 | Samsung LN52A850 52 in. LCD HDTV
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Intermittent loss of picture and sound,
its is flashing 10 times the power button on my 1080p plasma tv
Nov 22, 2009 | Televison & Video
Samsung 46" DLP TV no picture or sound
Replace the TV, the cost to repair is about what new costs.
May 18, 2017 | Samsung DLP HL-P5663W 56" TV
No picture or sound/wont power up
Your mainboard is damaged, the mainboard is the one where you plug all the cables (component HDMI), it is really easy to replace, you only need to take special care with the screws.
1. remove all screws in the back.
2. unplugg all cables from mainboard.
3. remove all srews from mainboard and replace it.
4. put all screws back and then plug all cables again.
5. double check all mainboard cables are properly secured.
6. Test TV.
7. put the back cover and secure it with the screws.
8. Enjoy your TV again.
May 30, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Samsung LN-S3251D 32 in. LCD HDTV Logo
147 people viewed this question
Jerry Greenberg
Jerry Greenberg
