My siemens rev 16 hydronic will not heat even when the ignition light is on. it clicks on and it sounds like it has started but then stops a few minutes later.
  • 2,272 Answers
Always look at the bottom of the screen at the 24 hr clock to see what time the thermostat is programmed to come on and off.You can then instantly see if your heater
should be on either T*& temp or TC temp. if the heating is not on when the time clock
indicates that it should check  to see that the time is set correctly.
Also check out the battery voltage.Is it  low or OK.
For Rev 16 manual.Click on the link mentioned below:--
http://www.google.co.in/#hl=en&q=siemens+rev+16+hydronic+&aq=f&aqi=&aql=&oq=&gs_rfai=&fp=f272b46d404fdcb9
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 22, 2010
Recently purchased and moved into older home with a hydronic radiant heat system with boiler. Upon running the system in the colder temps, we are hearing a gurgling sound recurring in some of the runs
typically hydronic systems like that need to be bled, start with the highest radiator, the bleed valve have a little square head and you need to have a key that fits them, most supply HVAC houses have them sitting on the counter but you can ask them for one.
Jan 14, 2015 | Heating & Cooling
Why doesn't heater heat up when turned on ?
  • I bought 3 convection heater ( model 052-2026 ) .Two of them stop to heat after 2 years using . The third, stop to heat last december. Canadian Tire ( store where I bougt the product ) told me to contact Garrison Company . Now , I want to get refund. Michel L?ger Quebec, Canada
Mar 04, 2014 | QMark Portable Hydronic Electric Baseboard...
Bentley continental GT engine stops all power turns off (even hazard warning) key won't come out of ignition
need to check the charging system..when a car sits for a long time the battery should be disconnected or compl,etely removed..sounds like operating voltage is too low check the alternator for stuck brushes or malfunctioning regulator..should show around 14.5 -16 volts..
Feb 24, 2013 | Bentley Continental GT Cars & Trucks
24' x 48' shop, insulated 1/2 mechanical, 1/2 wood working: Most economical heating long & short term ??
Re-post question and carefully say what you are doing.
Sounds like you are choosing system to distribute heat, and are debating hydronic baseboard heat, and electric blower.
Water or air hydronic systems are slow to heat, and pipes can leak but the system is not as intrusive as ductwork needed for electrically blown heat. Electric blower can heat space more quickly. Both systems needs to be designed properly to distribute heat correctly.
Jun 28, 2012 | Hardware & Accessories
Ingiter will either fail to start burner or won't quit clicking on the 1% of the times it does start up the burner
Hi look for adjustments to the lighter and also there should be a sensor tat sees the fire , this sesor allows the main gas to turn on, but only if it feels the heat , kind of like a thermocouple , if you think about about any type problem like this: what is it not doing ? then think what could cause this >/? if you go about any repair this way there is nothing you can't fix unless you need a part !
Dec 05, 2011 | Jenn-Air JGC8430 Gas Cooktop
How do I wire 2 Hydronic 1500W 240V heaters together?
Please follow the attached wiring diagram on page four on the web link below.
Hope this helped you....Jim...Please leave a positive comment if it helps you with your project.
http://www.thermalinc.com/comfort/PDFs/LF_instructions.pdf
Feb 14, 2011 | Fahrenheat Electric Hydronic Baseboard...
Heating & Cooling Logo
920 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
