Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
How can I tell if my fuel filter needs to be replaced. My mower the ys 4500 quit running the other day so I figured it was the fuel filter or line but how can I tell if it is the problem
  • 10,865 Answers
Hello. IF your spark plugs are good, and your air filter is clean, and your fuel tank is not close to empty, the next thing to check is the fuel line and the fuel filter. As a general rule, I change the fuel filter every 40 hours and the fuel line every 200 hours. J.
Posted on Jul 22, 2010
Riding mower v twin acts like its running out of gas how to check what is wrong
Does it idle normally, but only start starving of fuel under load or high revs?
If so, check the fuel filter - just a simple plastic cylinder that the fuel line runs through before going into the carburettor. Quite cheap and easy to replace.
Aug 26, 2013 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
My garden tractor is not holding it's battery charge. I replaced the battery, but still doesn't hold a charge after I use it.
If you replaced the battery with a new one and it is not holding a charge, then your charging system is not putting out enough power to run the mower AND recharge the battery. So you need to figure what is wrong in the charging system.
Mar 26, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Runs but blades wont activate
The drive belt on my YS 4500 keeps coming off. You need to put it back on, by hand, if it's not too hot. You just need to find the route of the belt.
Aug 08, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How do I drain gas from tank craftsman ys 4500?
disconnect fuel line from fuel filter, snake fuel line over to left side of engine. Remove gas cap and fuel will empty out of fuel tank.
May 15, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a DYT400 Craftsman mower. Fuel is not getting to the carburator.Could it be the fuel pump?
Most likely or look for a fuel filter in the lan to see if it is clogged. if you take the hose off to the car and crank the engne, fuel should come out. in not, trace the line back to the tank to find the filter if there is one.
Nov 20, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have an 18 HP Craftsman tractor (model 917255980) that will not start. If i remove the fuel line from the carb, gas does not run out freely, hoever, by applying suctin on the line gas does flow breifly....
The pump is not good,to test it,you take out the out fuel pipe start the engine ,see if fuel is coming out fully to the pipe,if sometimes it comes and cut,this means the fuel pump is not working properly.You have to change it.
Sep 06, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
YS 4500 Stalls out after running for 20 mins
I do believe they change plug(s) and air filter? There could be impurities and water in tank. Check for any loose electrical connections. Problem with valve clearance. Keep me informed.
Jun 13, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
291 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
