Question about Logitech X-540 Computer Speakers
No sound at all.
I've had these speakers for some time but after spilling beer into the volume control they started to play up and started getting quieter untill eventually just turned themselves off.
I washed the volume control with hot water and left it to dry in an airing cupboard and now they turn on, and the speakers making a clipping sort of sound when they go on (whch I think is normal) and I can get sound out of the headphone jack, but they speakers wont play anything at all. I've tried different sources but there isn't even any noise when you rub your fingers on the lead.
  • 19,396 Answers
Hi.
I am afraid that washing the volume control with water was not the right thing to do. Water will grow oxide that create shorts and cleaning with water will inflict further damage to circuits and components.
After liquid damage you need to allow the disassembled circuit coplete drying, letting it rest in this state for a couple of days.
After that you clean circuit with a no water cleaning solution like this one.
If that does not work, components must be tested, and eventually replaced, desoldering and soldering new ones. Testing is done starting from volume potentiometer that is tested reading Ohms with power off. If there are gaps in Ohms reading while turning volume wheel, then the part must be replaced.
Posted on Jul 27, 2010
Volume stuck on mute for wireless speakers
After pairing it, have you tried to go to your sound settings in Control Panel and selecting the bluetooth device as your standard sound device?
Oct 25, 2012 | Computers & Internet
My usb speaker wont play through pc
Is your usb port working? Try another usb port. Are you sure the speakers work? If so, try the speakers on another computer and see if they work.
Look at your Audio and Sound Properties in the control panel to make sure the volume is turned up and not on mute. Click Start/Control Panel or Start/Settings/Control Panel and look for Audio or Sound. You can also get to the Audio and Sound Properties by clicking the megaphone at the bottom right near the time.
May 31, 2012 | ASUS Computers & Internet
How do I find out why my computer has no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps you
Apr 15, 2012 | Dell Dimension 4100 (-JM0TB01) PC Desktop
My logitech x530 speakers are not playing
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 28, 2011 | Logitech X530 5 Speakers
My laptop has no sound yet I have no money to purchase a sound driver. can I get a free one
Laptop's sound can fail to work for a couple of reasons:
(1) the sound drivers are not properly installed - as far as I know, every computer manufacturer's web site will allow you to download their hardware drivers for free. Hope you've already done that.
(2) the sound hardware in the laptop are either disconnected or failed - a small number of laptops actually use separate sound cards (instead of integrating the audio hardware on the main board). Hopefully you've already checked that, too.
(3) the audio output jack (headphone) is damaged - in which case the sound hardware is functioning 100%, but there's no sound produced due to a shorted jack.
That being said, if it's neither of the above, the cheapest means of getting some basic sound to a muted laptop would be a USB sound card and a set of external laptop speakers. If it sounds elaborate and expensive, I assure you it's not. Assuming you're running Windows (hopefully XP or newer), you can buy a USB sound card on eBay for around $2 and pay about the same price for a cheap set of cheesy laptop speakers - plug the USB sound card into a working USB port, plug the speakers into the USB sound card, it's plug and play, and ... viola - you'll get $4 worth of cheap sound. It's a bit cumbersome but it's a cheap workaround that I've done before when a laptop went mute and I had only a shoestring budget to work with...
Sep 08, 2011 | Computers & Internet
My ATP3 suddenly making some noice (Not all the time) when not in use (No audio is playing; but power is ON). During the time of play speaker volume falls into lower level and shift into normal level. ie,...
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 07, 2011 | Altec Lansing ATP 3W Computer Speakers
The speakers wont work no sound
This article contains tips for resolving sound related issues in Windows XP.
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 10, 2010 | Logitech V20 Computer Speakers
When i plug in my logitech headset whitch is usb plugin the music plays go over the headset.But when I unplug the headset music does not play over the speakers.How do I fix this so it playes over my...
Start - Control panel - Sounds and Audio devices - Click on the "Volume" tab. Check that the device volume is included in your volume control (Advvanced - Options - Properties)
Also check your speaker Volume and Settings.
May 16, 2010 | Microsoft Windows XP Professional
My speaker sound
If you are using Windows XP, click >Start>Control Panel>Sound, Speech and audio devices> again >Sound, Speech and audio devices> then check the "Device Volume" control. Also check the controls under "Advanced" button.
Feb 15, 2009 | Polk Audio AMR50 Computer Speakers
I have gateway boston digital BA735 on a dell dimension 3000 with soundMAX integrated digital audio sound card but get no sound from speakers. What can i do to get speakers to work?
we have to check whether the issue with speakers or in sound card..just remove the audio jack from computr and touch the jack with ur fingers..u shuld hear some noise in speakers..if u can able to hear that speakerrs are fine and the issue with the sound card..do reply
Jun 17, 2008 | Computers & Internet
Logitech X-540 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
