Question about Kodak EasyShare Z760 Digital Camera
Memory card will not format in Kodak Z760
I have inserted a new Kodak SD memory card in my Kodak EasyShare Z760. My display says "Memory card requires formatting". When I hit "continue" I get an hour glass and the display says formatting. However, within about 2-3 seconds, the camera kicks out of formatting mode, and I am unable to format the card.
    Genius:
  • 1,234 Answers
Hi There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    I put a SDHC memory card in it and it said to format it.
    The Z760 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
    Aug 28, 2011 | Kodak EasyShare Z760 Digital Camera
    I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
    This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
    Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
    Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
    I just put in a new SD card in Kodak Z760, but it needs to be formatted. How do you format the card?
    There is a function to format memory cards somewhere in the camera's setup menus, but this might not be the problem. Most cards come pre-formatted. If this card is more than 1GB it will be SDHC instead of SD. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
    There is no reason not to try formatting the card, but if it won't format or isn't usable after formatting, then it may be incompatible.
    Nov 27, 2010 | Kodak EasyShare Z760 Digital Camera
    We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
    Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
    Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    Kodak easyshare c613: memory card says its full when there is no pix on it, what happens is: i turn it on, says "memory card full", i go to review, says "no pictures or videos to display on memory card",...
    If you connected the camera to the computer with a USB cord to download your pics and then just yanked out the cord without using the "safely remove hardware" icon at the bottom right corner of your screen, the card may have been corrupted. Replace it.
    Nov 10, 2009 | Kodak EasyShare C613 Digital Camera
    Kodak EasyShare DX4530 Digital Camera Digital Camera Cannot format memory card After I inserted new card, it says that memory card required formatting....I hit Continue...it warn me that formatting will...
    If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
    Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
    Nov 08, 2009 | Kodak EasyShare DX4530 Digital Camera
    Cards not working with camera
    If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Kodak EasyShare Z760 Digital Camera Logo
    372 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
