Question about Yahoo Mail
I am in my documents it is in catagory I want to get back to classic
  • 624 Answers
Hello and Welcome to FixYa!
You can switch b/w Mail Plus and Mail Classic, the pictorial representation is given by Yahoo Help, Please find the Link below.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Link
Posted on Jul 22, 2010
How to fix my kitchenaid mixer hit bowl?
The height of the beater to the bowl is adujsted by the screw found when you tilt the head back.
Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 26, 2014 | KitchenAid K45SS Classic Stand Mixer
Tip
A Quick Fix for many old sticky drawers
We all have one of those old wooden dressers or kitchen silverware drawer that drives us nuts because it catches. I now an a very easy solution that does not require installing a ball bearing set of slides though the end result is pretty close.
The old way used to be to remove the drawer and sand/wax the runners (wear surfaces).
The most difficult part of this is properly removing the drawer. Some simply flop out, their contents all over the floor. Other have stops to prevent this. Here's how to handle those:
Drawer Removal
Do this by releasing the latch at the back of the drawer. Some push in (spring models like on Singer Sewing machine drawers)and on really ancient antique furniture they are simply gravity operated. A stick of wood that has a small part sticking up and a much larger heavier part below attached by a single screw. It pivots on this screw. So rotate it 90 degrees either left or right then gently remove the drawer, supporting it underneath.
Ultimately it is best to remove all the drawer contents FIRST since you will be for the next step anyway. Better it on the table than all over the floor!
You will need one product to make this work. You go to your local hw store or home center and buy any teflon spray THAT DRIES. It must dry and not stay wet.
Carefully spray the bottom runners of the drawers with a light coat. If you're worried about the finish use a piece of shirt cardboard against the side of the runner so no overspray hits the finish. If you are uncomfortable and the item is expensive, just mask off the sides with newspaper.
But with a little practice and keeping the nozzle very close (1/2 to 1 inch) away from the drawer side runner bottom you will be able to do this easily.
Hitting the inside of the drawer also helps but is not neccessary.
The the spray dry (usually white) before reinstalling. Slide it back and forth many times. Remove and respray any area that are not white anymore -- the product wore onto the wear surfaces in the dresser. This is a good thing.
After doing this most drawers will slide almost as well as if you had spent $40-$100 on a set of professional slides like the new kitchen drawers have.
I did this on a 1950s dresser I refinished and I am just amazed at how well it works. I invented/discovered it just by experimenting with it on wood.
This compares favorably to my first drawer I built in woodworking shop in school. I spent hours sanding that from 180 to 220 to 320 and finally 400 sandpaper and then waxing it and buffing it. It slides well but the above proceedure is far less time consuming than this.
So go! Get a can of dry-setting teflon spray, available for around/under $5 at most home centers and do every drawer in the house! You're life will be so much easier.
I've done every drawer in my place, even a classic mahogany tambour type sliding door for a home entertainment center. That was a custom conversion from a 1960s B&W TV that I reused as a home entertainment center. It covers the system and has the class of real wood furniture. I mention this because I think this would also work on sticky tambour classic rolltop desks as well. I know they are getting repopular again for computer stations. I've seen them in the high end mailorder catalogs as well as custom designs in my favorite woodworking magazines.
But I came up with this tip all on my own. It started in my woodworking shop. Unfortunately now it won't let me put it in an appropriate catagory -- furniture drawers. Building is maybe the cloest?
Management: Maybe you can find the right catagory or create a furniture catagory? Or a Miscellaneous "Around the house" tip catagory. People who google the problem will still find it.
on Jul 12, 2010 | Office Equipment & Supplies
How do I delete my question, It has been posted in the wrong catagory
Just redo it in the correct catagory and submit again
Feb 15, 2013 | Cars & Trucks
Blue book on 2003 fr1000?
Two things. Not sure if you have a car, truck , or motorcycle. This is he car and truck catagory, list in proper catagory if it is a motorcycle.
Second, Kelly Blue Book, usually shown as KBB.com will have prices. They have catagories for vehicles, boats, but not sure if you have a motorcycle. KBB may have that catagory. Otherwise, for what you have, try some Blogs. Blogs are 2-way conversations and you may be able to ask someone who knows.
I hope my solution is helpful. For whatever you have, age, hours used, condition, and the Region you live in all are factors. AutoTrader.com and similar publications may turn up info. Also enter your unit on The Web as a general search. You may find similar items for sale.
Sep 19, 2012 | Cars & Trucks
RCA R52WH74 HDTV Television MAKES NOISE POWERING ON
Thats the classic sign of a failed deflection board. You can get the ITC222A deflection board which comes with warranty and installation instructions from www.tvrepairworld.com its listed as the ITC222A remanufactured deflection board under the RCA CRT Projection Circuit Board catagory
Apr 01, 2012 | RCA HD52W59 HDTV Projection Television
How to save my documents to lexar 2gb jumpdrive
You can simply drag the My Documents to the drive, that will make a copy. But you could also use the backup function of Windows (simply type 'backup ' in the Windows help and follow instructions).
Jules
Mar 02, 2009 | Lexar JumpDrive Classic Portable USB Data...
Mouse left click problem
it is possible you changed the scheme for your mouse pointers.
you can reset it back to the windows default by going to "control panel", then if you are using the catagory view, you would select "printers and other hardware" Next, select "mouse".
( if using classic view, simpy select "mouse" from the control panel).
Next, while on the "mouse" screen, select the "pointers" tab. At the top, there is a drop down menu for " Scheme". Choose either None, or Windows Default, and then click "apply" and then "ok".
Close out all control panel boxes and test.
Good Luck :)
Sep 30, 2008 | Dell 2 Button Mouse 6u226
Changing fluid in CRT's
You can go to the following site, under the repair kit catagory they have a CD that documents the step by step proceedure for coolant change in phillips / magnavox tvs with pictures. They also have the entire kit with 48 ounces of high purity coolant and the cd
Heres the link.
http://servicemanuals.vstore.ca/
Jul 11, 2008 | Televison & Video
Ipod Classic Firmware rollback
Go to C:\Documents and Settings\*your user name*\Application Data\Apple Computer\iTunes\iPod Software Updates.
Delete the firmware you don't want, in your case it'll be "iPod_24.1.1.1".
Turn off the internet (turn off the router/whatever).
Connect the iPod, then click Restore. As iTunes cannot connect to the internet and get the newest firmware (1.1.1), it will use the latest firmware in that folder, rolling you back to 1.0.2.
Apr 23, 2008 | Pioneer AVIC-D3 Car DVD Player
Yahoo Mail Logo
23 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
