Nintendo 64 Console Logo
A
Anonymous Posted on Jul 06, 2010
My n64 keeps freezing every game i try works for a coiple minutes then freezes what do i do to make it work?
Anonymous
Level 3:
President:
  • Master 894 Answers
  • Posted on Jul 21, 2011
Anonymous
Master
Level 3:
President:
Answers
894
Questions
10
Helped
122201
Points
2619
Well maybe the console needs to be cleaned out then dust causes videogame consoles to heat up 10 times faster than their normal heating rates.
1helpful
All of my other N64 games work perfectly, but when I put in Donkey Kong 64 it always freezes during the 64 logo or the Dolby thing. I tried trading it in for a different one, but the second one freezes in...
Well there could be an internal issue with the console then or video games consoles are senseitive to heat and it could be an over heating issue. Dust acts as a baricade and it makes video game console over heat 10 times faster than their normal rate.
1helpful
My n64 keeps freezing, a lot of times before it freezes the game goes silent. meaning all the sound in the game goes away and your still able to play for a couple minutes before it actually freezes. any...
Well the console might need to be cleaned out then. Dust causes video game consoles to over heat 10 times faster than there normal heating rates. Theese pictures might help you out then.
4helpful
2answers
My nintendo 64 is freezes in the middle of when I am playing it. Now when I re-start it to play the game again the red light would signal that the nintendo is on but no picture is going on the TV. Is it...
Well if it freezes and the screen turns black and than the tv screen says no signal and the light is on i had a problem like that with my 14 year old N64 console so it looked like it was dead and died but it was the expansion pack that did this it makes it look like it died but it didnt.
4helpful
2answers
N64 game freezing
Well its the console thats making the burning smell becuase its a power supply failure warning or its over heating for this to happen. I had my N64 console for 14 years and never heard of this before. I has to be the console or the ac adapter then.
1helpful
I've had my N64 for a long time. Now when I turn it on, the screen just flashes and doesn't do anything. Sometimes it works for a couple minutes then freezes. This happens with all my games.
make sure the game port is clean and the game itself is clean. use rubbing alcohol on a cotton swab and lightly rub it on and see if any dirt comes off
10helpful
2answers
N64 freezes while playing
The Nintendo 64 is notorious for overheating problems.  This is a very common problem.  With my N64, I play it while a fan is blowing on it.  This usually prevents the problem.  Try this method.  It should work.
Hope this helps!!
Please give feedback.
Kirby 64 won't hold a save file
The battery inside the game pak has died, thus, it can no longer hold a save.
Buy a special screwdriver for n64 Game Paks. Unscrew the casing, then find the battery inside the Pak. Take it (the battery) to any store that sells watches, then ask for a replacement for that battery. Plug the batery (+ side facing you) in the Pak, then screw it back together.
Your game should now save. :)
1helpful
Freezing
I have the same problem with my genesis. Most likely it freezes if you make the cartridge move any, which is hard to avoid on these older consoles. Same goes for any cartridge based console i.e. NES,SNES,N64 sega
Theres a cheap way to keep the cartridge from moving though, heres what i do; As your inserting the game, wedge something like a quarter, or a small piece of cardboard with the game. It keeps the game from moving, and thus keeping it from freezing.
hope this works for you!!
Something inside n64 game cartridge
There could be many things making that noise, my fellow N64 Gamer :)
It could be a few loose pieces of plastic that have broken off over the years, or it could be the chipset itself, which would be the reason why it's not working. By a special screwdriver off the internet (not more that 10 bucks) and open the cart to see what's making the noise.
As for the freezing up, if the chipset's moving around in there, it cold be freezing, if the chipset isn't moving, you could try cleaning the contacts on the bottom with a solution of alcohol and water.
Based on what you said, you need to clean you prongs on both the console and games. Also, blowing into it can help too. If that fails, you might have a short in your system and need a new one.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
