Question about Yamaha DSP-A1000 5-Channel Amplifier
Su-x501manual I am woundering if they is any site that has the manual for the amp su-x501
    Problem Solver:
  • 10 Answers
Cricket ZTE X501
How do I unlock my zte x501 phone
Feb 19, 2014 | Cricket Wireless Cricket - Zte X501 Groove...
Su-x501 turning off intermitently
If your unit is intermittent, check the speaker wires on the back of the amplifier for stray threads of wire, next! the printed circuit board underneath should be checked for bad or cracked solder joints, finally one more parts are defective, tough problem to nail down, recommend technician.
Jul 08, 2012 | Technics Audio Players & Recorders
I need an Operator Manual for a Technics Amplifier SU-600
HI,
I have the User manual of Technics SU-600 in pdf format. If you can sent your email address the i will sent you the manual.Its not possible to sent the manual through this site as it is a pdf file.
OK
Oct 26, 2011 | Technics SUV500 2-Channel Amplifier
Techics new class A digital integrated amplifier SU-X501. Unit switches itself off after a short while when playing cd or records? Any ideas why?
Is this happening in a regular pattern. If so please check from the mains power section.Check from the plug, the socket, use another outlet if possible to check. If the faultt recurrs, then you willneed to open the set when it trips off, check all the connectors, the main PCB for any signs of bad joints caused by dry soldering in heating sections. If so use a good iron to resolder these sections bbut attempt only if your familiar with these circuits. Next notice if there is any excessive heating when it is cutting off, if so reduce the treble and bass to confirm any transcient noise running the amp.Use another source to recheck if the noise is coming from the present one. I hope this helps. Good day
Jun 14, 2010 | Technics Audio Players & Recorders
I want to no how to wire the hole system up just picture diagram SU-X501
This appears to be a tough one to find for free. There is some info out there - but it will cost a few bucks. The service manual or sometimes called a "shop manual" is for those that work on damaged units - and is probably over the top for your needs. The operating manual or owner's manual is likely the same as the one that came with the unit when new. Either can be had at the site below for $15 and $10 respectively:
http://www.manuals-in-pdf.com/index.php?main_page=advanced_search_result&keyword=Technics+SU-X501+manual&forward=plist
I am not affiliated with this or any other site that charges for manuals, tips, advice, etc.; and only offer it as a source for the info you're looking for. I hope this helps!
Jun 11, 2010 | Technics SUV500 2-Channel Amplifier
Need to replace my Technics SU-X501 Amplifier.....HELP!!!!
its better to buy desame brand of your unit for compatibility sake...
Jun 19, 2008 | Audio Players & Recorders
Sound from one speaker only.
your output stage had a problem in electronic output device and must be maintained in service center.
Nov 03, 2007 | Audio Players & Recorders
Channel has switched off.
Make shure speaker wires are not crossed at amp or at speaker terminals. Check balance control is at center. Check sound with headphones to see if final amp to speakers is the problem. Try switching imputs on back panel from right to left see if same speaker is on,.Try all loudness controls and tape dubbing buttons to see if any are dirty.
Good Luck
BIG RED
Yamaha DSP-A1000 5-Channel Amplifier Logo
378 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
