Question about Malber WD1000 Front Load Washer/Dryer
Malber wd1000 hi..does anyone know what settings to use on the three dials for a regukar wash and dry load???
  • 55 Answers
Two of the dials are dryer settings. There is only one washer dial, which basically controls the length of the wash and rinses, etc.
Posted on Apr 23, 2008
How do I dry clothes
Either hang them up wet or put in clothes dryer
Nov 26, 2014 | Malber WD1000 Front Load Washer/Dryer
Malber wd 1000 just stopped working (power light won't go on) After a full wash and dry cycle the towels were still damp (started yesterday afternoon) was set to go through another dry cycle and it may or...
on my wd1000 i removed back cover and on top left side there is a electric/electronic component,i noticed a slight burn mark where one of the connections were.I cleaned and crimped it tighter and it has been fine ever since!
Sep 16, 2010 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Turn it on...no water?
Well it turns out that the pipes were not properly connected...however, I think the machine is very confusing anyway. This is my understanding of the Malber WD 1000...at this point in time. I've only used it once. The first dial (on the left) has to do with how fast you want to spin the clothes...I set it at 600 and that seemed to be fine for perm press. The second dial has to do with the temperature...I am still confused...it is the temp of the wash or dry? Its just darn right confusing. The third dial has to do with starting the wash. I put it on 3 for perm press. Now I wonder, if I turn it to 5, delicates, will it still go straight into dry mode? As a woman, I have a lot of things I dont like to dry, so if anyone figures this out before I do, please tell.
Aug 28, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
Aug 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Where do you gets parts and schematic?
check two places. repair clinic dot com and parts select dot com
Sep 06, 2007 | Malber WD1000 Front Load Washer/Dryer
Clothes are still sopping wet when finished
If your clothes are wet after the wash it is quite possible your outlet filter is blocked. Check this out and clean out. This requires periodic cleaning, according to your usage. Refer to your user manual.
Aug 28, 2007 | Malber WD1000 Front Load Washer/Dryer
Getting the dryer to start after turning it off.
Suggestion: Switch off wall plug and restart to dry.
Jun 26, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
148 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
