Black line vertically on scanned/printed documents
How do you get rid of this black line
  • 3 more comments
  • gsmcw Jun 25, 2008
    This line is not dirt or smudgy looking. It is a precise line that is two thirds to the right and vertical but not at 90 degrees. It's more like 89 degrees in angle. I have used this psc to scan several thousand pages and this is a new development. Hoping not to have to buy a new psc! I just looked at the position of the line and then looked at the ADF guides. The far one is most likely causing the problem, but is not dirty. What to do?
  • nancy900 Jul 30, 2008
    Same problem.....I cleaned the scanner glass and it's fixed! Don't know how the scanner glass got so dirty! Thank you so much!
  • Anonymous Aug 12, 2008
    On the mp530 I have this problem. can't find a manual on how to clean it.
  • soiltech Dec 06, 2008
    I have the same problem on a Brother MFC 7420. I installed a new drum & cartridge, cleaned the corona & rollers. What else could it be?
    Judy
  • Anonymous Mar 15, 2009
    I was getting a straight line down the middle of the page whenever I scanned a docment. Thanks to the MASTER, HenryG, I realized that the solution was simple: clean the glass. BUT, I didn't notice that the paperfeed on the top of my MFC7420 scanned through a smaller piece of glass on the copy bed. Facing the printer, it's on the far left and is about a 1-2 inches wide piece of glass.
    There was literally one little dot of a glue-y smudge on the glass and that's what caused the line. Thanks Master MFC Supreme, HenryG!
    New Friend:
  • 48 Answers
This problem can be caused by a number of different issues. If it occurs when you copy, check the scanning glass to see if there is any dust/gunk on the scanner glass. Also if you machine has a document feeder than you need to check the **** glass that the paper feeds past.
If it occurs when you print than you probably need to clean your printer. Check your manual for exact details on how to clean your printer but in general it could be on a paper feed roller or it maybe something on the drum. If you let me know what printer this is happening on I can direct you to a manual if needed.
Henry
Posted on Apr 22, 2008
5 Suggested Answers
antiochpc
  • 1314 Answers
SOURCE: vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Posted on Jun 01, 2009
leroyal
  • 2120 Answers
SOURCE: Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Posted on Jan 25, 2009
  • 313 Answers
SOURCE: A thick black vertical line appears whenever i
you have a problem in your scanner assembly, clean or replace it
Posted on Apr 03, 2010
  • 628 Answers
SOURCE: black verical line appear when documents are
Clean the glass on the extreme left side of the printer. Lift up the feed tray and clean the vertical glass. You probably have some debris on it, such as white out or some other stuff.
Posted on Mar 06, 2011
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
Black vertical line when copying a book page.no light leaks.
If it is along the edge of the print, it may be the edge of the book page you are seeing. if it is going through the text of the page, your scan carriage is likely skipping. If you don't see this on copies of single sheets of paper laid on the glass, then the weight of the book may be deforming the glass enough to catch the scan carriage as it passes. If you see it on single copied sheets, there is probably something on one of the scan rails under the glass that the carriage is "hopping" over as it passes. You could try watching the scan carriage move while holding the lid open to see if the carriage "hops" once during a scan.
Nov 10, 2013 | Panasonic KXMB2030 AllInOne Printer
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Black vertical lines when scanning on canon mx420
the ocr sensor in the ADF needs to be replaced, I would recommend replacing the whole ADF as a whole.
Aug 10, 2012 | Office Equipment & Supplies
Black verical line appear when documents are scanned from the feeder. How do I get rid of the vertical lines?
Mar 05, 2011 | HP Officejet 5610 All-In-One InkJet...
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dec 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
4,798 people viewed this question
k24674
jasbo
jasbo
