No manual have acer motherboard how can i find out which one it is so i can connect the power/reset/speaker etc
    Scholar:
  • 61 Answers
Most motherboard manufacturers actually print on the motherboards the model numbers etc. If you refer to the following link - look to the right of where you place the CPU and you will see white writing.
http://www.priceisrightcomputers.com/images/motherboard_gigabyte_7vkml.jpg
If your motherboard does not have this on it, you may be able to see the model number in the BIOS somewhere.
If you end up getting it working without the manual. Download a program called CPU-Z 90% of the time it will show what motherboard you are using.
Posted on Apr 22, 2008
  • 63 Answers
U can found it the manual from website acer
good luck..
thanks for using fixya
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard?
If you have knowledge of computer hardware and also have a tool for open the computer cabinet, look at the 9 pin on motherboard one is shot out of ten pin, in the pin panel there is market some word to connect the panel Like Pw bt -Power button, Rst-Reset, Pwr-Led-Display Led, HDD-Hard disk Led, and SPK-Speaker Button. Inser all cable acordingly which is allready marking with coat sign
Sep 23, 2014 | Acer Aspire 7720 Notebook
I have installed a new motherboard in an acer case. The power cable from the switch on the front of the case will not connect to the board. Can anyone help? Thank you
You should read the motherboard manual, for cabling:
1. Power SW
2. Reset SW
3. HDD led
4. Power led - and power led +
5. Speaker
Cabling scheme, also written on the motherboard.
If the Power SW not installed the switch on does not work.
If the Reset SW not installed the switch reset does not work
If the HDD led
not installed the hard drive light (red) is not lit
If the Power led (+/-) not installed the power light (yellow) is not lit
If the Speakers are not installed, when the computer is on the beep sound is not heard.
I hope this information helps.
Oct 15, 2011 | Computers & Internet
I got a mother board from a friend it a k9n6sgm-v but i can find where i have to connect my speaker-HDD LED my rest switch all the front panel
http://www.msi.com/service/download/manual-4593.html
If you follow the above link, you can download a pdf of the manual. On page 7 at the bottom you will find a diagram showing where to plug in speaker, power LED, HDD LED, reset switch etc.
Aug 16, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Acer Veriton 3600GT motherboard - sound/usb not connected
Use the link below to download the manual for your motherboard. http://support.acer-euro.com/documents/manuals/desktop/manual_veriton_3600gt.html
See page 54 for your motherboard layout.
Apr 11, 2010 | Acer Veriton 3600GT PC Desktop
Where to attach reset key wire on motherboard? its ax4bs.. pls help me my computer is nt working bcoz of it
Here is a link to the motherboard manual:
http://usa.aopen.com/userdownload_List.aspx?RecNo=3473&Model=254
The manual has the plug pinout for the reset, power, speaker, etc.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 19, 2009 | Acer AOpen AX4BS-V (91.89J11.001)...
I'm looking for manual i need JPN1 setting pin outs for power switch, speaker, etc
hello, look at the motherboard clearly or you put it under light, you will see all the jumper pins labeled with or printed with white paint, the name of each connection pins is written on the board. the speaker is far from the power switch,the reset pin is by the side of the power pin, the HDD light and the power light are opposite each other.to make things simpler, i suggest you forget about the reset and other ones and concentrate on the power pin. bridge all the pin with a screw driver to locate for the power pin i.e two pin at a time.
Aug 06, 2009 | Soltek SL-75FRN2-L Motherboard
HDD,Power switch,Reset pin configuration
Google your motherboard and download the manual for it, or post the model # for it here. The manual will show the pin out. In general, the pins are usually abbreviated on the motherboard, albeit, very small. The wires will usually be marked HDD, RST, speakers,etc. Sometimes the pin outs are color coded on the mobo, just connect the wires to them color to color.
Jan 25, 2009 | Computers & Internet
Emachines t6522
I assume you are trying to connect the wires from the faceplate to the motherboard. Get a magnifying glass and see if the board is marked as to Power, Speaker, HDD LED, Reset, etc. Trace the wires to the faceplate and note what the function of each pair of wires is and attach to motherboard as necessary.
Jan 17, 2009 | E-Machines eMachines Desktop PC
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Acer motherboard MS6772 ver 1 Can you help me with the pin out for connector FP1 please This is the connector with reset and power switch drive led etc
This board uses typical INTEL styled pin header for front panel connections and is used on many major OEM boards. Here is the pin assignment:
Pin 1-3 HD LED (Red color in this particular board)
Pin 2-4 Power LED (Green)
Pin 5-7 RESET
Pin 6-8 Power ON/OFF
Note: Pin 10 is empty
Mar 10, 2008 | Acer (ACERMOTHERBOARD)
Computers & Internet Logo
1,079 people viewed this question
David Payne
David Payne
