Better colour setting for videocon 24 carat tv
I am not getting proper picture quality . how can ia get better picture quality in videocon 24 carat flat tv
Drummernick
  • 440 Answers
SOURCE: colour problems
try to go in menu do factory reset ok
Posted on Feb 03, 2008
ButtFuzz
  • 463 Answers
SOURCE: vizio 42" fhdtv - need help for better picture quality settings
Since you're using "analog cable", I would adjust the television such that the picture is not streched. This means there will be black bars to the left/right of the 4:3 picture, but you should experience some improvement in picture quality because the TV is not trying to interpolate what to do with an already crappy analog cable signal.
You may also want to add a signal booster where the cable first enters your residence... often, folks split that analog signal up so much it is weak... and looks much like you describe.
Posted on Mar 09, 2009
  • 176 Answers
SOURCE: new flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Posted on Jan 06, 2010
supernova278
  • 1932 Answers
SOURCE: I purchased a mitsubishi WD63658
As the picture of the blu ray is realy good then the problem is with the cable line only and with the TV.
Please check the atenea orentation so that you get the better picture.
If you are using cable the operator Dish may be having a problem.inform your operator.
Thanx
Posted on Jul 30, 2010
  • 360 Answers
SOURCE: Videocon tv ----on screen showing
Your panel is locked due to child lock. Procedure to unlock it may be given in the operating manual.
sonsunny
Posted on Jun 17, 2011
My videocon 21" colour tv's screen colour changed to green
you problem with your picture tube.I recommed you must replace your picture tube for better view
May 05, 2014 | Televison & Video
How to make colour best in ps2 game
your tv will have more control of colour/picture quality. but depending on what cable you are using. if you are only using the S-video cable you will get better picture using the Component Video (Y, Cb/Pb, Cr/Pr) cable. change the video output setting from RGB to composite mode and that should improve the picture quailty
Mar 20, 2014 | Sony PlayStation Video Game Consoles &...
Poor picture and colour quality on hd through hd box red is pink fuzzy hd picture
You need to check the resolution of your TV thru your input setting, try to check which will give better picture quality between 1080 or 720 settings. Also secure that your input setting as either HDMI 1 or 2 or 3, you can use the original remote and change setting by pressing input in cycle.
Jul 08, 2011 | Televison & Video
Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
Look at the connectors on the back of your TV. You could have:
* coaxial input (lowest video-quality)
* S-Video input (better video-quality)
* component input - three cables for video, two cables for audio (better video-quality)
* HDMI input (highest video-quality)
Look at the connectors on the "output" side of the PVR. You could have:
* coaxial output (lowest video-quality)
* S-Video output (better video-quality)
* component output - three cables for video, two cables for audio (better video-quality)
* HDMI output (highest video-quality)
Connect the "outputs" to the "inputs", using appropriate cables.
Turn the PVR on. Turn the TV on.
Use the "source" button on the TV's remote-control to select from the various inputs
(Coax, S-Video, Component, HDMI1, HDMI2).
If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
Feb 03, 2011 | Computers & Internet
Bluish colour with Lumix TZ3
I found 2 different Lumix TZ3 cameras.
http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832097+250033510&Ne=&Ns=&Nr=12001&No=0&Ntt=tz3&Ntk=SupportSearch&URL=vSupportSearch&cmTag=false&cm_sp=&cn=&catalogId=13401&storeId=15001
In the manual, I couldn't find a reference to a bluish color.
In FAQ's, I found the following:
What is “Intelligent Auto Mode” (or IA Mode)?
“IA mode” automatically activates MEGA O.I.S., Intelligent ISO Control, Face Detection, Intelligent Scene Selector, Intelligent Exposure, and Quick Auto Focus to match your subject and shooting situation. IA Mode is a great mode for beginning photographers
http://www2.panasonic.com/webapp/wcs/stores/servlet/vSupportHowToGuideDetail?storeId=15001&idval=UCM_STG_CNT_032308&catname=Lumix+Digital+Cameras&title=How to Take Better Photos
Jul 23, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Picture quality
Make sure your zoom is not set to low also switch on the antishake in the camera menu.
Turn picture quality down slightly to either 6 or even 5mp ( I know whats the oint in a 8mp if you are going to turn it down) believe me it works better.
Aug 25, 2009 | LG KC910 Renoir Cell Phone
Problem in 14" videocon colour tv
whats the videocon portabel flat tv internal service mode code
Aug 09, 2008 | Televison & Video
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
