Question about Dell Computers & Internet
How the ribbons are run where the master and slave go. mine on startup it says unetected second slave
    Brigadier General:
  • 10,406 Answers
The motherboard will have two connectors for "ribbon" cables.
Each ribbon-cable has 3 connectors: one at each end, and one in the middle.
Thus, with two ribbon-cables, you can support up to 4 "parallel-ATA" devices (ZIP drive, LS-120 drive, disk-drive, CD/DVD drive).
Note that the 3.5" diskette-drive has its own ribbon-cable, and that ribbon-cable is not quite as wide as the other ribbon-cable.
How many devices do you have? Probably, one disk-drive, no ZIP drive, and one or two CD/DVD drives.
So, if you only have 3 devices, then the message is correct -- there is nothing connected to the SECOND ribbon-cable in the SLAVE position.
Tell your motherboard to "ignore" the secondary slave, if you have nothing connected at that position.
Posted on Jul 22, 2010
How can i make my Samsung sp0802 hard drive become the master instead of the slave... thank you very much
Hi Good day!!! follow this
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
7. Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
Don't forget to vote thanks!!!
Nov 02, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
I need the book too know how too instal the jumperwho put the driver slave or master
hi
  • Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
  • Step 2 To change the designation of a new drive to be a slave drive, skip to step 4.
  • Step 3 To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
  • Step 4 Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
  • Step 5 Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
  • Step 6 Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
  • Step 7 Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
  • vote me if you solve your problem
    Jun 13, 2010 | Ximeta Hard Drive
    I am trying to instal a second disk drive but the system can only trecognise one at a time, how do i get to see both of them? it is a hp desktop 2004
    From your problem, it sounds like you are installing an IDE drive. If so, then both drives are most likely set to master. You want your original drive as master and the new drive as a slave.
    If your system supports Cable Select, this is the best option and both drive should be set to CS. The drive connected to the last drive on the ribbon cable is the master and the other drive is the slave.
    If you are unsure, just set the second drive to slave.
    Most drives have a label on top that shows you the jumper settings. The jumper on 99% of IDE drives is located between the power connector and the ribbon connector. If in doubt, all the manufacturers show jumper settings for drives on their web site for each particular model.
    Mar 13, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
    My second internal hard drive isn't showing up under my computer, but show in bios, and add harware Maxto 4R060J0 60gb
    Your 2nd. hard drive needs to be set up as a slave or master, this is done by the jumper in back of the drive. If you have a cd drive as a slave when connecting with the ide ribbon & are connecting the new drive on a different ribbon it needs to be set as master drive. A little more info on your prob. will help answer your question. When you see the drive in bios, does it say master or slave?
    Lee
    Dec 18, 2009 | Maxtor Hard Drive
    I was installing a dvd drive, unhooked main power supply in computer, now when I turn on computer it says it needs a systems reboot disc can you help
    The computer can't see the hard drive. IF the hard drive is on the same IDE ribbon as the DVD then you have a jumper problem. You need to look at the old cdrom if there was one and jumper new one the same as old one. (Master, slave or cable select) Also while you were digging around inside your computer did you pull the IDE ribbon to hard drive loose from the drive or the motherboard? Are the power connectors still hooked up? Every hard drive ribbon can have one slave and one master drive. Your hard drive should be the master and the cdrom the slave. Some systems are now set to "cable select" that means that the hard drive ribbon has a master connector and a slave connector and that the device (hard drive or cdrom) becomes a master if connected to one connector or a slave if hooked to the other one. If you go into your bios setup when you turn on the computer you should be able to look an see which of the drives or cdroms is hooked up as master or slave. Some will display this information during bootup posting.
    Oct 04, 2009 | Computers & Internet
    My new Liteon DVD iHAP122-9 is set as master over an CDRW which is set as slave. My DVD will not format or do anything except play cd and DVD's.
    all u need to do is to reaccess the data ribbon........
    jus open ur cabinet n have a look at the ribbon........
    if its a thick n small ribbon then its a SATA n if its a thin but flat ribbon then its a ID3 ......... in a id3 ..... one end is in the motherboard so the 1 connected to other end is set as master while the one in the centre is the slave........
    in SATA for for port no. near the socket in the board....... arrange ur slave in the port of which the no. is more than that of the master....... for eg. if master is in port 3 then slave will be in port 4 or 5
    Sep 26, 2009 | Computers & Internet
    Trying to add another internal hard drive to Dell Dimension 3000
    Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
    Robert
    Jan 24, 2009 | Dell Dimension 3000® Pentium® 4...
    How do i configure my Barracuda7200.10 AS PRIMARY MASTER
    When more than one hard drive is installed on a computer system, each drive competes for control of the computer. To allow both drives to work in harmony on the same computer system, the controlling (or startup) drive is designated the master drive and the other drive is designated the slave drive. You can change this designation. The following procedure applies to any PC-compatible computer.
    Instructions Difficulty: Moderately Challenging Things You’ll Need: Step 1 Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set. Step 2To change the designation of a new drive to be a slave drive, skip to step 4. Step 3To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable. Step 4 Check the hard drive documentation or the label on the drive itself for master/slave jumper settings. Step 5Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20). Step 6Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label. Step 7Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.") build_pc_xp2000_maxtor_40gb_jumper_matchup.jpg Set to label on your hard drive. Different on every drive.
    Jul 19, 2008 | Computers & Internet
    How can i install and format a hard drive
    Install the HD into your computer case with screws, connect a ribbon cable and a power cable, ensure that your HD is set to master or slave, depending on where it is installed in your drive chain (IE: only, or first, device should be master, second device should be slave). Startup the computer. Windows should recognize it, but if it doesn't, Under WindowsXP and above, goto control panels, open administrative tools, open Computer Management, Select Disk Management, find the new disk in the lower portion, right click on it, and create a new partition.
    Hope this helps!
    -Backu
    Jan 16, 2008 | Computers & Internet
    Second harddrive
    Make sure its jumper is set as slave, if you have a 40wire ribbon cable, and cable select if you are using a 80 wire ribbon cable, if it is on the same ribbon cable.
    If it is on the second ide cable, by itself keep it as master.
    Jan 15, 2008 | ASUS M2N-MX Motherboard
    Computers & Internet Logo
    115 people viewed this question
    Alun Cox
