Purchased a txv part no. bt1369064 can it used internally and horizontal.
Where is the expansion valve located on 2008 Saturn vue xe 2.4 liter engine, and how is it removed
The TXV is located at the front of dash and attaches to the evaporator inlet and outlet pipes. The TXV is the dividing point for the high and the low side pressures of the A/C system. As the refrigerant passes through the TXV, the pressure on the refrigerant is lowered. The TXV also meters the amount of liquid refrigerant that can flow into the evaporator.
Under the hood in the engine bay ,along side of the brake booster ,
Mar 29, 2018 | Saturn Cars & Trucks
Were is expansion valve in a 2002 Chevy trailblazer in the truck
Are your asking about TXV valve thermal expansion valve for A/C system ? If you are ,yours doesn't have one . Has an orifice tube , The orifice tube is located in the liquid line between the condenser and the evaporator !
The orifice tube is the dividing point for the high and the low pressure sides of the A/C system. As the refrigerant passes through the orifice tube, the pressure on the refrigerant is lowered. Due to the pressure differential on the liquid refrigerant, the refrigerant will begin to vaporize at the orifice tube. The orifice tube also meters the amount of liquid refrigerant that can flow into the evaporator.
Unless you are referring to the auxiliary A/C system for the back of the vehicle , it uses a
The rear TXV is located at the rear evaporator inlet. The TXV is the dividing point for the high and the low pressure sides of the rear A/C system. As the refrigerant passes through the TXV, the pressure on the refrigerant is lowered. Due to the pressure differential on the liquid refrigerant, the refrigerant will begin to boil at the expansion device. The TXV also meters the amount of liquid refrigerant that can flow into the evaporator.
May 23, 2015 | 2002 Chevrolet TrailBlazer
To change from R22 to R404, can the same txv be used?
Hi, no the txv will need to be changed they use different pressures. And i believe you mean r410a correct?
Sean
Mar 29, 2011 | Refrigerators
Any diagrams on installing a 410A TXV on a R-22 Evap coil?
You don't install a 410A TXV on an R-22 Evaporator coil.
If converting your system to a 410A, then you must be using a 410A condenser, and an evap coil, and drier rated for 410A.........
Dec 09, 2010 | Goodman Heating & Cooling
Fuzzy picture
Tryi going threw video jacks instead of coax cable see if that works better
Jul 18, 2009 | Mitsubishi VS-5047 50" Rear Projection...
My freezer will not hold temperature. Only a year
If what you say is accurate, I would look at either a weak compressor or and issue with the expansion device. (Cap tube, TXV)
What are your pressures and what freon are you using? Does the door(s) seal tight?
Jun 26, 2009 | Victory Freezers
I just had a bryant a/c installed (txv) should it have a hard start kit as well.
Anytime you have TXV they do need a hard start kit. The TXV shut down on the off cycle and does not allow unit to equalize. Rusty
Jun 11, 2009 | Goodman CLQ36AR49 Air Conditioner
RUUD 13 SEER HEAT PUMP MALFUNCTION 2009 MODEL
I sell Rudd equipment. You have air in the system or faulty TXV. Replace TXV and evauate system. No more problem. Rusty
May 27, 2009 | Heating & Cooling
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
