Question about Daewoo DWC-084R Air Conditioner
MY AIR CONDITIONER IS NO LONGER PRODUCING WATER FROM THE BACK
MY AIR IS NO LONGER THROWING OUT COLD AIR AND I THINK ITS BECAUSE THE WATER FROM THE BACK OF THE AIR IS NO LONGER THERE.. hOW CAN I MAKE IT WORK PROPERLY AGAIN?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
Check to make sure the filter is clean. If not, remove it, wash it and start it back up.
The water that you have seen comes from the machine cooling the air, the air conditioner literally squeezes the water out of the air. If it's not blowing cold ... no water.
If cleaning the filter doesn't work, you will probably have to have the unit looked at by a professional.
Posted on Jul 22, 2010
My Wife's care overheats and the heater only blows out cold air.
check that the thermostat is in correctly as it will cause no circulation but overheating. have a compression test done to eliminate head gasket /cracked head. There could be a blockage in the heater core but I am thinking that by passing the heater fan he has also by passed the actuator( coolant valve) for the heater core. Water pumps suffer from bad bearings and very seldom anything else. check that he hasn't blocked off the water to the heater core as well
the throwing back of the coolant is the boiling of the coolant in the block ( bad head gasket) due to lack of circulation. It may be a blocked radiator as flushing doesn't fix the blocked cores . If that is the case a new radiator is in order.
Dec 31, 2014 | 1997 Lincoln Continental
Takes long to get hot air, it does not overheat, air is not hot enough
if what you are saying is when its cold out and you start your car for the first time it take a while to get the heater to start blowing hot air but once you get going it works fine
you might want to try changing your thrmostat to one that opens a lower temp some open at 195 and others as low as 140
what happens is your heater uses the hot water that is used to cool your motor the therostat allows the water to flow thu the motor once the water in the motor has reached the set temp so on a cold morning the water takes longer to heat up and will then inturn take longer to get hot water to your heater allowing you to get hot air
get it ? i think i might be confused now
if you need help changing your themostat let contact me
a new one is less than $20.00
Nov 25, 2010 | 2000 Chevrolet Malibu
Pelonis Hot & Cold Water Dispenser, water not cold
I too am having just room tempature water coming out of the cold
dispenser and I have had mine for 1 month.........
Nov 03, 2009 | Kitchen Appliances - Others
Is not throwing out cold air. Cool air only.
Get up top and remove the plastic shroud. Gently rinse out the condenser coils with a water hose (do not use high pressure). Make sure that there is a good flow of water coming through the entire condenser before buttoning it back up. This should help.
Jul 02, 2009 | Coleman Mach III Air Conditioner
My heat is not working. Its throwing out very cold air now. It happen before and i replace thermostat and blew air threw heater core. I blew air threw heater core the other day now its throwing out real...
It sounds like your heater core is stopped up, or be sure your coolant is flowing, and picking up heat from your engine...Thermostat, water pump, etc.
Jan 30, 2009 | 2000 Chevrolet Blazer
My ac turns on but it only throws hot air it used to throw it cold a few days ago, whats the problem?
Adding a can of freon is not the solution, a system that has too much freon will not work right and there is a chance that you will damage the compressor.
There are low pressure and high pressure switches at work when the system is operating.
You might have a bad switch, leaves or other matter blocking the front condenssor.
Is the system actually full?
It's best to give this problem to a certified A/C mechanic.
Oct 01, 2008 | 2002 Jeep Grand Cherokee
Overheating and A/C problems.
If you get cold air when the heater is on, you have lost quite a bit of coolant. Now the question is what caused you to lose your coolant.
As long as you didn't drive around with your engine overheating, your engine should be fine. I think you would know if you had damaged your engine.
When the engine cools, fill your cooling system, start it up and check for leaks or overflow. If the only water your see is from the overflow when the engine starts to overheat, then it very well could be the water pump or thermostat. Chances are the thermostat will need to be replaced anyway.
If this doesn't solve your problem, write back.
Sep 26, 2008 | 1999 Pontiac Grand Am GT
E10 error code?
We had the E10 error code. I took off the water intake hose as the washer and the screen there was full of sand from our well. I cleaned the screen out and the code disappeared.
Apr 25, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Daewoo DWC-084R Air Conditioner Logo
498 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
