Question about LG RH177 DVD Recorder/HDD Recorder
Finalise disc how do I finalise the disc. i am recording DVD+R on a LG RH 117 recorder and (trying to) play back on a mac computer
  • mkuti Apr 23, 2008
    thank you. FIXED!!
  • 1,512 Answers
You need to put the disk back into the recorder, select the finalize function from the onscreen menu, and follow prompts. Do you have an owners manual for the unit?
Posted on Apr 23, 2008
  • Graeme Ross
    Graeme Ross Apr 23, 2008
    you can get a copy from here. The information about finalising your DVD is on page 21.
Can anyone with a RH1777 help me finalise my dvd blank disk with his/her recorder?
If you can't find someone with the same recorder you could try putting the DVD into a computer DVD drive. It might be possible to get the video files off the DVD. DVD files are called VOB. You can get free software that will play them. It might even rip the files from the disc for you. You can then transfer them to a DVD disc using the computer.
Jan 06, 2015 | LG RH1777 DVD Recorder
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
Recorded discs wont play on an other dvd player
you have to finalise the disc when finished recording then it plays on any dvd player
Feb 15, 2009 | Philips DVDR3380/05 DVD Recorder
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Dodgy DVD burner
After completion of recording in the DVD, you have to finalised the DVD then after u can read with other devices
Jun 02, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Hi there. You need to "finalise" the dvd before you can view it.
Apr 22, 2008 | LG RH177 DVD Recorder/HDD Recorder
Finalizing both sides
A Dual Layered (DVD-R DL) disc has two recording layers on the same side of the disc. No recording is made on the 'other' side of the disc.
Finalising the disc will finalise both layers. Most probably your computer DVD drive cannot read both layers of the DVD-R DL disc. DVD-R DL discs can only be played back on DVD devices that are compatible with dual layered discs.
Check your computer DVD drive spec to see whether it can read DL discs.
Mar 19, 2008 | Canon DC210 DVD Camcorder
LG RH177 DVD Recorder/HDD Recorder Logo
241 people viewed this question
Computer Repairing
Computer Repairing
