Question about Ulead Videostudio 8 for PC
ERROR IN MOVIE WIZARD
MOVIE CREATION PROCESS WAS ABORTED WHAT DOES IT MEAN?
ERROR 12345:2:3
  • evangeld Apr 28, 2008
    Using Del Latitude D830. Running Ulead VideoStudio Movie Wizard. I insert a Video (from a WMV file). Then click Next. I the the same error.
    Any ideas would be appreciated!
  • 3 Answers
Not sure what it means, but I found a way around it.
I get the same error when I try to burn a WMV (Windows Media Video) file to a DVD.
As a work-around, I converted the file to a MPG (MPEG-2) file. That took the size from 41 Mb to 357 Mb.
I was then able to burn the MPG file to a DVD successfully.
If you still have trouble, I would suggest creating an ISO image of the MPG file. That takes the size from 357 Mb to 508 Mb. You should then be able to create a DVD directly from the image file.
Evan
Posted on May 03, 2008
Have retry and abort up on screen Trying to complete password set up What does it mean and what can I do
Retry means your passwords either didn't match or, they didn't meet the password requirements. Abort means just that. Quit. Maybe start over with the process.
Mar 05, 2015 | Computers & Internet
Tip
Common FTP Error Codes
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy - mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; bout to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 File status.
213 File status.
214 Help message. On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1, h2, h3, h4, p1, p2).
230 User logged in, proceed. Logged out is appropriate.
250 Requested file action okay, completed.
257 "PATHNAME" created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information.
421 Service not available, closing control connection. This may be a replay to any commend if the service knows it must shut down.
425 Can't open data connection.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system. File unavailable (e.g., file busy).
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access).
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
on Jan 12, 2010 | Computers & Internet
Tip
COMMON FTP ERROR CODES
~~~~~~~~~COMMON FTP ERROR CODES~~~~~~~~~~
# Description
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
150 File status okay; about to open data connection.
200 Command okay.
212 Directory status.
213 File status.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. Where NAME is an official system name from the list in the Assigned Numbers document.
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
230 User logged in, proceed. Logged out if appropriate.
421 Service not available, closing control connection.This may be a reply to any command if the service knows it must shut down.
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy).
530 Not logged in.
on Dec 03, 2009 | Computers & Internet
What is roku pin
You can setup a PIN in the following ways:
  • During the Roku account creation process, or
  • Log into your Roku account from a browser, and click on "Update" next to Pin Preference
Mar 02, 2014 | Computers & Internet
Restor settings aborted
You cannot successfully restore the same way again when it has been aborted. You need a windows system disc and the drivers for your machine.
Disk can be downloaded as an ISO from Microsoft and the drivers direct from hp when you have the system working again.
Dec 21, 2013 | HP Pavilion Computers & Internet
C-FE07 error on a Konica-Milolta C250
The machine displays an abort code CFXXXX on the control panel as it becomes unable to process tasks properly trough its software control.When the sistem program is aborted,check the electrical componenet,unit,option and connection to the specific type of the abort condition.
CFE07 - ASIC 10 timeout number of DMA under operation and transfer completion line=0:DMA_D.Relevant electrical componenets MFP control board.Try to reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key while the Trouble reset message displayed.
Release the Utility key and touch the message and turn OFF the copier.
Wait 1 minutes and turn ON.
Apr 18, 2013 | Konica Minolta Office Equipment & Supplies
MOVIE CREATION PROCESS WAS ABORTED WHAT DOES IT MEAN? ERROR 12345:2:3
it usually means that the disk you are using is poor quality. try using a better quality and try again.
Jan 29, 2010 | Ulead Videostudio 8 for PC
I/o error occurred. Process aborted pops up
The Windows error "I/O Device Error" means there is an error in the computer's ability to read data when you try to install a program or to copy data from your device such as a CD Rom, external hard drive or digital camera. To resolve this issue, try connecting the camera to a different USB port. Also try to uninstall and reinstall the driver. If both suggestions fail, we would recommend trying it on a different computer to see if the camera is defective. If it works on another computer with no problems, the issue may be with the computer. We would recommend a Windows update or contacting your computer manufacture for further assistance. A simple solution that many other users try is a card reader.
Jan 22, 2009 | Fuji FinePix Z10fd Digital Camera
I/O Error process aborted when opening finepix viewer to download
I had same problem...Deleted Finepix software and used windows media player automatic plug and play...better program and uses less hard drive space :) (im running Vista Ultimate)
Dec 05, 2008 | Fuji FinePix Z10fd Digital Camera
Ulead Videostudio 8 for PC Logo
178 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
