Question about HP Photosmart C5180 All-In-One InkJet Printer
The hp Photosmart C5180 Printer I use at work keeps restarting itself over and over in a continuous cycle. How do I get it out of this ? I have tried unplugging it ?
    Problem Solver:
  • 6 Answers
It turns out, this is a design error. A capacitor on the control board was under rated for it's intended use. Open the side of the printer that has the power port etc. and access the board. Purchase a new capacitor 330 uF 16V or 25V and replace on the control board. It will be one of the two green capacitors on the board, check the markings on the side of the component. Verify which direction the positive and negative leads go and replace the parts. Power up to verify and then unplug and re-assemble. Hope this helps. PartWorst case $1.50. 45 mins. It takes longer to get the part and open the case than to fix.
Posted on Feb 18, 2011
  • akurt May 25, 2011
    hi, i need the specs for the c642 capacitor. can anyone help please? this is for HP c5180.
  • HP Master
  • 6,826 Answers
I read over the FAQ's and Troubleshooting on hp.com's website and couldn't find a reference to a 'restsart' condition over and over in a continuous cycle.
I was going to suggest unplugging it, but that you already tried.
I think there's something wrong with the board, but to replace would exceed the cost of buying a new printer. And I'm not sure if hp.com would even service it.
Contact HP.com and find your local partner using the following:
http://h20465.www2.hp.com/GPL/search.aspx?SearchType=SSP&country_code=us&language_code=en&jumpid=hpr_R1002_USEN
Posted on Jul 22, 2010
Document will not delete, keeps spooling
go to the devices and printers
click on printers click on --what's printing or printer tasks
high light and delete each line
Feb 10, 2018 | HP PhotoSmart InkJet Printer
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP C5180 photosmart keep turning off and on. Will
This is due to ON/OFF switch is having the issue. Repair/replace the switch with the help of expert engineer/service center experts will resolve your problem.
Revert back for more assistance.
Jan 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have a HP Photosmart C5180 printer and am trying to install it on my PC. I have the disc that says HP Photosmart C5100 series for Windows 2000, XP I get so far into the install and it tells me my print...
please perform the steps below and then try to install the software:
1. Click Start , select Settings , and then click Control Panel .
2. Double-click Administrative Tools .
3. Double-click Services .
4. Right-click Print Spooler and select Stop to stop the services.
5. Click Restart to restart the service.
6. Click OK .
7. Restart the computer.
Oct 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 doesn't turn itself on
You are not going to like what I am about to tell you but I have seen it over and over. It will cost you more to repair this printer than a replacement will cost. Inkjet printers area commodity today.
Aug 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP photosmart C5180 all in one: Ink system has failed
Here's a link to a procedure that one individual used to fix the same problem with his printer. I can't guarantee this will work in your particular case.
HP C5180 All-In-One Printer HARD RESET:
  1. Hold down HELP + OK button and unplug printer (could experiment with regular power-off, but I opted for brute force)
  2. Hold down HELP + OK button again as you plug the printer back in. Then power it on, if it doesn’t power on automatically. Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
  3. Now you can release the buttons and simply power it back on. (I held my breath, but that’s not required.)
    • I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
reference: http://www.mlnarik.com/jewel/2009/05/21/how-i-fixed-my-hp-c5180-printer/
Aug 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
Oxc18a0201 ink system failure. Apparently failed due to using non HP ink. HP recomends buying a refurbished replacement. The printer is HP photosmart C5180
1.-press key * # 2.-enter code 123 and select a Hardware faliure status 3.- Press clear OK and finish cancel for end restart print
May 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
Black ink not working on HP C5180 Photosmart
Try a hard restart, which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. If that does not work, then rerun the CD used to install the printer. Both techniques reprogram the electronics, to a certain extent.
You can also visit the HP website, to see what solutions are being offered for various printer problems. They probably have a number to call, in case you need to talk to a technician.
Hope these suggestions help you out.
Jun 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printer won't print
my HP Photosmart C5180 all-in-a-one printer keeps saying the yellow cartridge is out of ink and I have put a new one in. The printer will not let me print anything. How can I fix the problem?
May 21, 2008 | HP Photosmart C5280 Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
662 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
