Question about Quinny Buzz 3 Sulphur Jogger
Torn rubber on handle. Need replacement
The handle bar has a tear in the rubber cover. Where can I get a replacement. Thank you.
    Champion:
  • Quinny Expert
  • 223 Answers
Hi aparently all bike shops can replace it.
Posted on Aug 07, 2010
Replace a key actuator pad that is torn bad
The rubber key cover is one piece and not sold as a spare part. Take the radio apart, remove the pad and put a thin tape, such as a very high quality electrical tape and a small amount of RTV silicone under the tear. Reassemble, wiping off any extra RTV as you go.
Nov 10, 2013 | Motorola Talkabout T5420 (14 Channels)...
How do I fit a throttle grip to my 2010 fatbob fxdx. thanks.
First remove the switch cover
just under the handle bars there are two rubber covered adjustment screws, roll back the rubber covers.
mark where they are set, then loosen off both adjusters until you can unhook the ends of the cables in the handle
remove the old grip and install the new one being careful to have the cable hook-ups in the proper position
install the cable ends and replace the cover
tighten the adjusters to original settings, check to see if there is play in the throttle and if it is returning to the start position when released
make necessary fine tuning to adjusters then tighten lock nuts and replace the rubber covers
hope that helps
Aug 22, 2011 | Harley Davidson FXDX - FXDXI Dyna Super...
I am looking for a new rounded handle bar that you use to push the stroller along with. The foam on my one is damaged
unfortunately I believe you have to buy a new chassis jus for the handle bar. The best way is to just buy a handle bar cover for the handle bar. That will cover the damage and also protect it from further damage.
Sep 17, 2010 | Bugaboo Cameleon Stroller
When you run a wash there is some water on the tile floor. I found the rubber gasket inside the door is torn.
If the tear is small, try using silicon glue to repair it--clean the surface of the boot and apply the glue. Let dry for 24 hours before using the machine. If the tear is large, the boot must be replaced. It can be done from the front without removing the cabinet, but it's tricky. These tears usually occur when trying to remove jeans and a metal button catches the rubber.
Feb 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
Cracked Foam Rubber Handle Bars
You can get some sticky back velcro and only use one side and tape it on there,i did this to my bob duallie,you can get black velcro like this at target or wall mart.
May 11, 2009 | Valco Runabout Deluxe Jogger
Buzzing/humming noise that increases as you raise volume. So loud that you can not even watch tv
Hello snow1525,
You may have a torn speaker element. This is usually the cause of buzzing noise in the sound, also you may have a bad capacitor in your audio section. This is what I would suggest doing as a test open the front bottom panel of your TV and visually inspect the speakers for signs of ripping and or tearing in the speaker element. If the element or elements are torn it may be possible to repair it with rubber cement or rubber paste just coat the tear with the rubber cement to hole the torn edges together and allow it to dry for two days before testing the sound. If the speaker elements are not ripped then the problem may be a bad capacitor either in the audio section (power supply) or in the filter block (usually attached to the speakers to separate bass and treble signal to the speakers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 16, 2009 | Televison & Video
I have Kyocera Mita Copier which is giving error code J20 and shows signs of overheating
Paper misfeed in the Left Cover internal section (J20, J30, J40 to 45, J50,
J52 to 56, J60, J61)
When the paper misfeed has occurred in the Left Cover internal section,
use the procedure below to clear it.NOTE: Supplementary Information
The drum section inside the main unit is sensitive to scratches and
contaminants. When removing paper, be careful not to touch it or scratch
it with your watch, ring, etc.
1 Grasp the Left Cover handles to
lift the cover and open it.
CAUTION: The fixation section inside the main unit of the copier is
extremely hot. Exercise caution in handling it to prevent getting burned.
2 Remove jammed sheets of paper
carefully so as not to tear them.
NOTE: If the paper is torn, be sure to remove all remnants or fragments
from the cassette.
3 If the Duplex Unit (option) is
installed, lift it up and remove the
paper.
from the cassette.
4 Close the left cover.
Jan 28, 2009 | Kyocera Copystar CS-1620 Black and White...
Torn foam covering on handle
Hi there's a place in america that sells replacement zip up foam covers for the Quinnys, do it in various lengths so you can also get one for your bumper bar at the front if thats a bit tatty as well. They are about £20 including shipping which is fairly reasonable considering how much the cost in the first place! Go onto ebay and look for 'quinny handle cover', and there's also companies on ebay that do replacement quinny stickers as well for a few quid as they wear so quickly.
Jan 19, 2009 | Quinny Buzz Jogger
Beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Bugaboo Frog Foam Handle ripped
On Ebay, if you type in Bugaboo on the search field, there is an item called Stroll-air that covers the handle bar. I think it's made of neoprene (like wetsuits) or something that looks like it.
Jun 24, 2008 | Bugaboo Frog Stroller
Quinny Buzz 3 Sulphur Jogger Logo
188 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
