Question about Samsung CLP 300 Laser Printer
Paper is stuck. All cords are correctly attached. What should I do?
    Guru:
  • 366 Answers
  • Step 1
  • Open the front panel of the printer. Look to see if the jammed paper is visible.
  • Step 2 Pull the paper if you see it. Pull gently so you do not damage any other part of the printer.
  • Step 3 Open the next panel. This panel is usually found below the already-open panel.
  • Step 4 Pull the paper if you see it. Again, do so gently.
  • Step 5 Open the next panel. This panel can be found towards the back.
  • Step 6 Pull the paper gently if you can see it. Continue to open any remaining panels, and then remove the toner cartridge.
  • Step 7 Look for the paper by taking out all removable parts. If you still cannot find the paper, replace everything and attempt to restart the printer.
  • Step 8 Once you have removed the paper, restart the printer. You will have to print your document again.
  • Read more: How to Clear a Paper Jam on a Laser Printer | eHow.com http://www.ehow.com/how_2006054_clear-jam-laser.html#ixzz0uOCeh3UK Hope it helps.
    Posted on Jul 22, 2010
    How to solve sharp 400 all in one error p6
    Unplug power cord. Ensure paper tray is attached correctly and no paper is jammed.
    Jun 14, 2014 | Sharp Office Equipment & Supplies
    Multifunction Canon mx 850 memory/in use light flashing ........will not print
    1.Connect the phone line cord to the correct port on the MX850 :
    http://goo.gl/Z8NPr
    2.Disconnect and reconnect power cord to reset the device At the device or at the electrical outlet, disconnect the power cord or adapter. Wait approximately ten seconds and then reconnect the power cord. Wait until the device has completed its cycling process before submitting another job request.
    3.Hang up extension phone .
    Sep 11, 2011 | Office Equipment & Supplies
    Its always saying that BACK COVER IS OPEN we already check it for many times but its intact and in correct possition. and also the paper wont feed the machine.
    Hi there!!
    The message that you're getting means that either the back cover is not closed securely or there's a jammed paper inside. Here's what you can do to clear the message:
    -Please unplug the fax machine for your safety -Open the front cover -Remove the toner & drum assembly (theres a handle in the center of the drum/toner assembly, just pull it towards you. -Remove any pieces of paper stuck or the jammed paper -Remove the toner from the drum and check for any other pieces of paper stuck -Once everything is clear -Reinstall the toner back into the drum and the drum & toner assembly to the fax machine. You should hear it click into place once installed correctly -Close the front cover & plug in the power cord. That should clear the message
    Hope this helps, Thumbs up if it does, thanks!
    May 08, 2011 | Brother IntelliFax-2820 Laser Fax
    Hello, My printer says that I have a paper jam but I can't find anything. I took all the paper out and put it in again. I turned the pirinter off and on. Nothing works. The page that originally got stuck,...
    Great job on taking out the paper jam without tearing it. Maybe the sensor got stuck and printer keeps thinking it's still has a paper jam. Remove the ink cartridges from the printer. Close the cover. Unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging it back in the printer. When the printer's ready, reload the cartridges then close the cover. If this doesn't help, I strongly suggest you contact Lexmark technical support to further investigate the problem. Thanks
    Aug 04, 2010 | Lexmark X4650 InkJet Printer
    Keepes saying paper jammed but there no paper stuck
    Turn off the Printer
    Remove the Rear Access door
    Check for any bits of paper stuck in the rollers
    Clean the Rollers with lint free cloth ( upward exactly how the paper rollers)
    Open the Front access Door, Check for any paper stuck.
    Close the doors and try to turn on the printer
    If this does not work, Disconnect the power cord from back of printer when printer is powered on.
    While holding the OK and Cancel button connect the cord back.
    Jun 23, 2010 | HP Photosmart 4180 All-in-One Printer
    I had a paper jam and I took the back off and this
    Step one: Remove any loose paper
    Remove all loose paper from the input and output trays.
    1. Turn off the product.
    2. Unplug the power cord from the back of the product.
    3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
    4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
    5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
    6. Carefully remove any jammed paper.
    7. Close the cover.
    8. Reinsert the rear-access panel or the duplexer into the product.
    9. Plug the power cord back into the product.
    10. Turn on the product.
    Step three: Open the top cover and clear the jam
    3. Open the carriage access door. The carriage moves to the right side of the product.
    4. Gently pull the paper out of the rollers.
    5. After clearing the jam, close the carriage door.
    6. Plug the power cord back into the product.
    7. Try printing a document.
    · If the issue is resolved, do not continue troubleshooting.
    · If the issue continues, proceed to the next step.
    Step four: Clear the jam from paper tray 1
    1. Remove all paper from the output tray.
    2. Turn off the product.
    3. Unplug the power cord from the back of the product.
    4. Lift the output tray and then check for jammed paper in input tray 1.
    Use these steps to remove any jammed paper.
    a. Raise the output tray.
    b. Grasp the jammed paper and pull it out of the product, toward you.
    c. Lower the output tray.
    5. Plug the power cord back into the product.
    6. Try printing a document.
    · If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
    · If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
    Step five: Clear the jam from paper tray 2
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    3. Remove the ADF input tray and open the ADF cover.
    4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
    5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
    6. Check the ADF paper path for jammed paper.
    7. Check for jammed paper where paper enters the ADF paper cleanout.
    o If the paper comes out with gentle pulling, proceed to step 9.
    o If the paper does not come out with gentle pulling, follow these instructions.
    1. Open the ADF, and then use both hands to gently loosen the paper.
    2. When the paper is free, gently pull it out.
    3. Close the ADF.
    8. Lower the green lever.
    Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
    9. Replace the ADF input tray.
    10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
    o Make sure that the ADF frame is secure and attached correctly.
    o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
    o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
    Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
    1 - Stack stopper
    2 - Two-catch
    11. Plug the power cord back into the product.
    12. Turn on the product.
    13. Try printing a document.
    Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
    Hp5550 paper jam
    Please check to make sure you have followed these instructions to clear the paper jam and check the carriage movement. Also check the mechanical parts described here and here to see that they are correctly positioned and moving freely. For stuck cartridge position, see here.
    You may have to reset the printer, as follows:
    2. Unplug the power cord and the data cable from the back of the product.
    3. Unplug the power cord from the wall outlet.
    4. Reconnect the power cord to the product and wall outlet, and then turn on the product
    Here's a key to the lights blinking errors.
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Jul 28, 2009 | HP DeskJet 5550 InkJet Printer
    Epson R320 carriage jammed
    The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
    Remove it and reinsert it, making sure that it is fully located, before applying the power.
    Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
    Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
    HP OfficeJet 6110 All-In-One
    To start with first try a reset:
    Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
    Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
    Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
    until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
    Then check and see
    If not try the link bellow:
    http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00804&dlc=en&product=79477
    Good Luck please let me known if nay problem.
    Oct 08, 2008 | HP Officejet J5780 All-In-One InkJet...
    PAPER JAM
    SUGGESTION #1 The print carriage might be jammed. Follow these steps to correct the problem:
    1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
    2. Disconnect the power cord from the all-in-one.
    3. Remove both print cartridges.
    4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
    5. Close the print cartridge access door.
    6. Plug in the power cord.
    7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
    SEGGUSTION #2 cleaning rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
    1. Turn off the all-in-one and unplug the power cord.
    2. Remove the rear access door (as describe above in this document).
    3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
    4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
    5. Re-seat the rear access door.
    6. Plug in the power cord and turn on the all-in-one.
    If these suggestions don't fix the problem feel free to write back to me. Try to be a little more specific i.e does paper feed properly, error message shows with paper/without paper or both, do any of the lights flash when this happens, have you tried diiferent paper sizes ot types. Have you taken it apart to check for any obstructions?
    Jan 06, 2008 | HP PSC 2355 All-In-One InkJet Printer
    Samsung CLP 300 Laser Printer Logo
    250 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
