I understand you remove the panel and then for a
1990, it has a handle and you simply pull it straight out.
REMOVAL & INSTALLATION
On models with an airbag, wait at least 90 seconds from the time that the ignition switch is turned to the
LOCK position and the battery is disconnected before performing any further work.
There is no indication, pictorial or otherwise, for the layman to orient to in this description. This "help" assumes that the reader knows what "trim panel" means in regard to this procedure. Is it the lower "trim panel" that completes the dash under the steering wheel? It appears on our Corolla that this must be removed before any access to the radio/stereo compartment is possible. A bit more specificity is needed in this article to make it usable.
Mario from nova scotia , canada
question? procedures on how to replace airbags and any modules on a toyota corolla 2002.
e-mail: [email protected]
thanks,
Mario
SOURCE: Removing Toyota Corolla 1990 Car Stereo
the plastic frame around it should snap out with a flat head screwdriver to get access.
The
Toyota Corolla has been around long enough that many owners find
themselves needing to replace the factory stereo. Installing a new
stereo in the Toyota Corolla gives improved sound and updated
features. Swapping out the stereo in the Toyota Corolla takes basic
tools and less than an hour. This article covers models from 1990 to
2000.
Open
the hood and remove the negative battery cable from the terminal.
Apply the parking brake and place the car
in "D."
