Question about Kenmore 13485 Wine Cooler
Kenmore wine cooler 13485 spill wine in the top not cooling
Kenmore wine cooler 13485 spill wine in the top shelf now is not cooling. check compressor ok, suction line warn liquid line hot. look unedr the top shelf and looks ok no water damage apparently. on any of the boards
    President:
  • 1,891 Answers
If suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Posted on Jul 22, 2010
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Why should I buy a thermoelectric wine cooler as opposed to a compressor model?
There are many reasons to purchase a thermoelectric cooler including, but not limited to, being quiet and eco-friendly. Personally, I prefer thermoelectric coolers because they don't vibrate. The vibration of a compressor cooling system can cause the sediments in the wine to be disturbed and affect the flavor/taste of the wine.
Jul 31, 2012 | Furniture
Troubleshooting kenmore wine cellar model 183.14242500 will not turn on just clicks
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 21, 2011 | Kenmore 13485 Wine Cooler
Our kenmore wine cooler started leaking water all over the floor.
I don't know how it is leaking water, it isn't hooked up to a water supply. better start looking for the actual source of the water
Mar 23, 2011 | Kenmore 13485 Wine Cooler
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
The magic chef wine cooler was clicking now will not get cool .
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
Jan 17, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Clearance??
hi you need at least 3 inchs clearance from the back ribs to the wall for good ventilation if there is no ventilation back there you will need to do 1 if to whole room is hot then you can install a fan that will cool down the heat from ribs good luck
Dec 20, 2005 | Kenmore 13485 Wine Cooler
Kenmore 13485 Wine Cooler Logo
288 people viewed this question
Top Kenmore Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Kenmore Furniture Expert? Answer questions, earn points and help others
