Question about Philips SA3025/37 Flash MP3 Player
Related with usb.
When connected to computer with usb no data transaction is possible. mp3 player gets charged.... hope i receive a solution soon...
  • 820 Answers
Coby mp3 player
Try to reset it if possible.
If the computer charges it then the computer recognizes it as a connected device. That's how usb works. It could be you need a new USB cable. Many devices that use USB for charging do not have the data leads connected in their cables. This is called a "vampire" connection as it only sucks 5 volts DC from the computer/charger .
Apr 03, 2014 | Coby MP-705 Digital Media Player
I can not charge the 2gb AMT MP3
The MP3 player is charged using the USB cable when it is connected to the USB port of your computer.
Oct 29, 2012 | Audio Players & Recorders
Can't turn on my mp3 player. I have tried to hold the volume buttom but it does not turn on at all.
what type of mp3 player ?
Charge your MP3 player.
The battery might just be dead, in which case letting it charge for a few hours corrects the problem.
Plug the USB data cable into the USB port on the MP3 player and insert the other end into one of the USB ports on your computer.
In a moment, the computer states that it has detected the removable device.
Sometimes the MP3 player needs to update itself, and it can only do so while connected to a computer.
When the MP3 player detects the computer, it attempts to connect to the Internet and retrieve any system updates available for the device.
Replace the battery.
The battery is usually the first part of the MP3 player to go (especially after excessive use). Although you can manually change the battery on most MP3 players, you need to send your
Apple products (iPod, iPod Nano, iPod Touch, iPhone) into the company so they can change the battery for you.
Purchase a new MP3 player.
If your MP3 player has received any sort ofwater damage, it is not going to turn on at all and there is nothing you can do to fix the issue.
hope this helps
Sep 27, 2012 | Audio Players & Recorders
I have Sony NW-E503 (256 MB) MP3 Player. I have a problem when am charging my walkman I get a message "CHARGE ERROR". Can someone help me solving this problem? I am charging my player with...
I'm sorry that the Player is not charging as expected. It is possible that the usage of non-original cable will give the Charge Error. Please follow the below troubleshooting steps and check the operation before purchasing the original cable to make sure that the issue is not with the player or the connectivity.
  1. Please make sure that the USB connection to the Computer is secure and firm.
  2. Try connecting the player to a different USB port on the Computer.
  3. Avoid connecting to USB hubs.
  4. Try removing other USB devices otherthan keyboard and mouse.
  5. Restart the Computer and try again.
  6. Try connecting to a different Computer to confirm the issue is not with the Computer.
Thanks for understanding. Please let me know if you require any clarifications.
Oct 18, 2011 | Sony NW-E503 (256 MB) MP3 Player
I just got the mp3 player. ive been charging it but when i disconnect it from my computer it shuts off and wont turn back on. HELP!
Some older computers that have USB ports that limit the output to 5V @ .5 amp current. Depending on your MP3 player, it may not be sufficient to charge the player. This was the spec back then. Since then, new USB specs call for 5V @ 1.0 amp current - a two fold increase in current.
You may have better luck connecting to a powered USB hub instead. If you're only looking to charge the MP3 player, you don't even need to connect it to the computer. The powered hub gets powered by connecting the ac adapter / power supply to a wall outlet - instead from of the computer's power supply via mother board.
The above assumes there is a good, rechargeable battery; a functioning charger & USB port in the MP3 player and of course, a working USB cable. If any of the above is faulty, you'll never get the MP3 Player to accept a charge. You should try different computers, cables and ports if possible.
Sep 07, 2011 | Computers & Internet
Can you keep player plugged into usb charger while playing music files indefinatly or will it over charge and possibly cause damage? im shopping around and am not even shure it will play while pluged in to...
You can keep the Sansa plugged in without fear of overcharging. The Sansa will play while it is connected to a USB port that is supplying only power, such as a USB charger operating off a car cigarette lighter. It will not play while connected to a computer.
Mar 09, 2011 | SanDisk Sansa Clip MP3 Player
I can not find my power cord for my m4002a mp3 player where can i get a replacement cord
To charge it from your computer?
Any usb cable that you can plug into your player should at least charge it
Take it to a computer/electronics shop and ask for a usb cable to fit it.
There are two types, charging and charging/data, with the data cable having all wires connected through so you can put music on your player from the computer.
I checked on eBay and put in "rca m4002 cable".
I found one for under $7 including postage, charging only.
Jan 28, 2011 | RCA M4002 Digital Media Player
How to charge My Mp3Player
Hi giannuandi,
Plug it into a USB port, and it should charge by itself. Use the USB cord Apple supplied for transferring data.
Dec 05, 2009 | Apple iPod shuffle MP3 Player
Computer doesn't recognize Creative Zen Mozaic
may not be a data cable. might only be a charging cable. Try different cables since that cable(if original ) is over 8 years old and possibly bad now.
Feb 02, 2018 | Beond Creative Technology Zen Mozaic MP3...
Philips SA3025/37 Flash MP3 Player Logo
161 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
