Question about HP Business Inkjet 1000 - Printer - colour - ink-jet - Legal - 1200 dpi x 1200 dpi - up to 23 ppm (m...
HP Business Inkjet 1000 lights blink, no jam found, but won't print
I am installing a new HP BIJ 1000. I followed the startup and installation instructions carefully, but when I turn it on, the power and resume lights blink. Troubleshooting says to look for paper jams, but it doesn't even try to pick up the paper. The printhead cartridge moves around and a cassette of some sort moves between the ink crtridges and the printheads. I've checked the installation of the cartridges and printheads, made sure all packing tapes were removed, paper is loaded properly, etc. Any suggestions welcomed. Thanks.
  • Anonymous Jun 11, 2008
    power led & paper led continousely blinking.
  • Anonymous Dec 02, 2008
    Exactly the same issue.
    B
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
IB4G2008
  • 3587 Answers
SOURCE: HP Business Inkjet 3000
you may wish to clean the nozzles, and do a clean and calibrate
Posted on May 07, 2008
printech
  • 159 Answers
SOURCE: HP Business Inkjet 2800
the carriage need maintenances
Posted on Jul 30, 2008
SOURCE: Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Posted on Aug 10, 2009
Testimonial: "Good answers - unfortunately still no closer to solving the problem."
  • 173 Answers
SOURCE: New 6500 OfficeJet installation issues -doesn't recognize printhead
you will need to contact HP for replacement parts here is there technical support # 800-474-6836 they are open 24-7
Posted on Oct 30, 2009
I have hp deskjet 1000 printer. when i replace blk/white cartidge the printing work didn,t complette. somebody tell me check your printer nozzle and clean it . but i didn,t find the nozzle button anywhere....
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken.
Thank you for using Fixya
Sep 23, 2011 | HP Business Inkjet 1000 Printer
Yellow light blinking and I cannot print
Most likely, the light that is blinking is the Resume light.
When this happens, you should check the following conditions:
The printer might be out of paper.
Place paper in the input tray, and then press the Resume button.
There might be a paper jam.
The printer cartridges are not installed correctly.
Mar 05, 2011 | HP Deskjet D4160 InkJet Photo Printer
HP Inkjet 1000. I have installed 2 new
the printer is pretty much in a Freeze state.. so turn off the printer.. remove the power cords.. keep it out for atleast a minute and then reinsert the connections back and then try to turn on ur printer.. it will surely resolve ur issue..
May 10, 2010 | HP Business Inkjet 1000 - Printer - colour...
Triagle light blinks on HP Laserjet 1022
If only the triangle light blinks then is because one of the following reasons:
1.The print cartridge door is open.
2.The printer is out of paper.
3.The print cartridge is installed incorrectly. Try opening the door, removing the cartridge and installing it again. It should snap into place.
4.There is a paper jam. Remove the cartridge and check if there is a paper jam.
Feb 06, 2010 | HP LaserJet 1022 Printer
Top light blinking, will not print
I believe that the top light is the low printer cartridge signal. Did you replace the cartridge or just take it out and reinstall it? Did you use a new HP cartridge or refilled cartridge?
Try a new ink cartridge from HP and double check that you have the correct cartridge for your printer. If that doesn't solve the problem, contact HP.
Sep 15, 2009 | HP DeskJet 5550 InkJet Printer
HP HP Business Inkjet 1000
If the printer is new, then maybe the printer catridge nozzle seals have not been removed and so the catridges are not being detected.
If it has been working before and then the problem starts, look at which light is blinking  because the paper and catridge lights are different. So check wich light is on and get to me for further instructions.
thnx
Jul 31, 2008 | HP Business Inkjet 1000 - Printer - colour...
HP BIJ 1000 - Reliability and Performance
I have the exact same problem. 1 Page okay, then ****.
Feb 22, 2008 | HP Business Inkjet 1000 - Printer - colour...
HP Business Inkjet 1000 - Printer - colour - ink-jet - Legal - 1200 dpi x 1200 dpi - up to 23 ppm (m... Logo
780 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
