Question about HP Pavilion dv9000z Notebook
My HP screen flickers then the brightness dims so I cant see anything on the screen
  • HP Master
  • 32,281 Answers
The fault could be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instruction to determine the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Jul 22, 2010
Computer screen dim
go to contol panel> power settings. Find screen brightness option for both "plugged in" and "battery". Turn the slider up all the way.
Jan 30, 2014 | HEWLETT-PACKARD ProBook 6550b XA673AW...
My screen is extremely bright/white , difficult to
try to use the auto adjust button. if it doesn't work you have to go to the nearest service center in your place
Jul 18, 2010 | HP L1720 17 in. Flat Panel LCD Monitor
My brightness is very low. I can't see anything
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 14, 2009 | Toshiba Computers & Internet
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
My HP Pavilion dv5000;s monitor is blinking!
This is a possible problem with the inverter that powers the back lighting panel or it could be the power adapter connector on the latop.
Wriggle the power connector which plugs into the laptop, if the LCD screen flickers then the power connector is faulty or needs resolderng (repairing).
Jan 28, 2009 | HP Compaq Pavilion dv5000z Notebook
MacBook Screen Problem
Hi there
If I understand you correctly from start up the screen is dim but does brighten up after time? But now after start up you are getting a flicker how ever a restart solves this.
On the dimming issue. Check your energy saving settings and brightness key is working OK.
The flickering is a bit of a concern.
Just a couple of questions.
Are there any dead spots on the screen? Areas where there are no pixels.
When you tilt the screen forward and backward, does this effect the brightness or flickering?
Paul
Sep 03, 2008 | Apple MacBook Mac Notebook
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Treo 650 screen brightness
Try Pressing the Option button and then P to bring up the Adjust Brightness control enabling you to dim or brighten the screen.
Dec 29, 2007 | Palm Treo 650 Handheld
HP Pavilion dv9000z Notebook Logo
169 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
