Question about Hotpoint Aquarius WMA52 Front Load Washer
Need to change push button on off switch for a hotpoint wm52
Need to change push button on off switch for a hot point wm 52 just need to check which wires go where
  • 1,998 Answers
There should be a wiring diagram inside the machine if you are unable to find the goto searsappliance parts online and they should have a wirein diagram for you
Posted on Jul 22, 2010
WM series. Where can I get a service manual?
WM is not a lot of help, since LG, Hotpoint, Beko and I think Samsung too, all start WM...... However, that said, there is a huge selection of free downloads on Manuals Online. Take a look here: http://laundry.manualsonline.com/manuals/device/washer.html
Sep 22, 2015 | Hotpoint Washing Machines
Do a tumble dryer have a reset button once you have changed the thermostats?
check the heating element they might be the problem if they are not getting any power or are open.
Aug 27, 2014 | Hotpoint Dryers
Hot point wm vlsr1090g3ww leaking
Is this a top loading machine? Are you seeing water flowing through the overflow or are you thinking that may be your problem? Asking because I've personally never had a prob with that tube. Leaks have always been attributed to other causes. Top loading hotpoint leaks are usually caused by a leaking transmission seal, water drain pump, inlet valve or faulty pressure switch. Need more info sorry.
Dec 08, 2012 | Washing Machines
My hotpoint wm52 won't start ,its completely dead no lights ,have checked sockets,plugsand fuse all ok ,have also changed interlocking system still nothing
main timer is blown along the door lock tracks. you can repair it with a soldering iron and a small length of wire. It blew because the interlock went faulty
Mar 28, 2010 | Washing Machines
Hi how do i fix brushes to a hotpoint wm52 washing machine
Remove lower rear cover of washer
Remove drive belt.
undo 2 bolts securing motor to drum.
Push motor away from you, it may be tight.
Unplug motor lead, noting which way it is plugged in.
Remove earth lead.
You will see the brushes at the rear end of the motor
There are several types of brushes fitted to these washers, it all depends on the type of motor you have, but all the brushes are readily available.
Reassemble in reverse order.
Please your comments.
Thanks
Barkencoa.
Nov 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine loud bang, now no water
you could have a broken or clogged bump,as far as the latch not opening it could be slightly off line
Nov 05, 2009 | Washing Machines
Locate brushes on a wm52 hotpoint
hello there are 2 black clips attach to the motor either just slide them out and slide new one in good luck
shaun
Jul 29, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint First Edition 1000 WM52
I had same problem. Had to replace brushes on motor. Easy enough job to do yourself
Jan 04, 2009 | Hotpoint First Edition WMA12 Front Load...
Hotpoint aquarius half load
you can only select half load if you wm has a half load button or switch found on the cosol panel
Feb 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA52 Front Load Washer Logo
189 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
