Question about Epson DFX-9000 Matrix Printer
My dfx 9000 Print is giving me an error 3 - Shutdown printer. What is wrong with it.
What is the meaning of "ERROR 03 on my dfx 9000
you have to clean the CARRIER ENCODE SENSOR SCALE
which is a <<tape>> under the printhead and detects the movement of the cr assembly
Aug 18, 2014 | Epson DFX-9000 Matrix Printer
Error : paper jam Epson DFX-9000
I find problem printer epson dfx-9000 with mesage
error : 0E
turn off printer
help solution this problem ????
Sep 14, 2010 | Epson DFX-9000 Dot Matrix Printer
Opened my printer espson dfx 9000 and im getting an error 16 how do i overcome this?
OPENED MY PRINTER EPSON DFX-9000 AM GETTING AN ERROR 16 HOW DO I OVERCOME THIS
Jul 23, 2010 | Epson DFX-9000 Matrix Printer
Error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
Aug 29, 2009 | Epson DFX-9000 Matrix Printer
DFX 9000 Printing problem
when i switched on epson dfx9000 printer its showing Error 01,Pls give the solution.
Dec 17, 2008 | Epson DFX-9000 Matrix Printer
Epson dfx-9000 printer is showing error 0D when it is switched on
check print head built in thermistor and the carrier cable.
Nov 20, 2008 | Epson DFX-9000 Matrix Printer
Re dfx -9000
Please perform the following steps to ensure your printer is physically functioning.
1. Turn the printer off and disconnect the interface cable.
2. Load plain, single part tractor paper into the printer.
3. Press the LOAD/EJECT button while turning on the printer.
NOTE: The self test prints over several pages. After the first or second page has printed, press PAUSE and turn the printer off.
If this self test prints correctly, then the printer hardware is functioning correctly.
>Try printing from other applications.
>Check cables as they can cause communication errors.
>Re-install the driver.
>Go to support.epson.com for more information & documentation.
Sep 08, 2008 | Epson DFX-9000 Matrix Printer
Dfx9000
The SP motor brake signal did not switch on within 3 seconds after turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM BOARD: CNSPHS, CNSPM)
2. Check the Interlock switch, and if necessary replace the switch assembly
3. Check both the SP motor and driver. (Always check both.) Check fora broken fuse on the SP motor 42 V line.
Replace the motor assembly and/or ROM BOARD as necessary.
Jul 08, 2008 | Epson DFX-9000 Matrix Printer
Epson dfx-9000
the SP motor brake signal didn't switch on within 3 seconds after turning printer on.
check for disconnected SP motor-related connectors. the printer needs servicing.
Jan 15, 2008 | Epson DFX-9000 Matrix Printer
DFX 9000 error oC
09 : FAN1 driver error
0A : FAN2 driver error
0B : FAN3 driver error
0C : FAN4 driver error
Jan 11, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
325 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
