Question about Kenwood KDC-3028 CD Player
Radio does not turn on when the tunner comes up
As soon as I see the channel comming up the radio dies out , I have to
unplug the radio for 20sec and re-plug for it to comme back up , I also re-run new power to it thinking a bad connexion , groud , still don't work , I also unplug all the speaker , still do the same thing , the radio is on my boat .
  • waleedhodhod Nov 15, 2008
    the tunner is not working. When i press standby button tunner desplay for one second then it will be suddinly dies. if i will make it on again i have to press reset button.then screen will be on again but the tunner not. please tell me what to do for this problem.
  • 160 Answers
Sounds like the radio blew a resistor, or a diode, usually it's cheaper to replace it.
Posted on Jan 09, 2010
Toyota Camry 1992 blows DOME20A FUSE when radio is turned on. RADIO and CLOCK will not come on.
pull the radio and unplug the connector. Replace the fuse. If it does not blow than replace the radio.
Aug 18, 2015 | Toyota Cars & Trucks
LOST CHANNELS ON MY PHILIPS FLATTV 42" RETURNED
Problems in the IF section of your tv.or tunner is faulty.replace tunner.have a tech repair your tv. good luck.
Sep 26, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My flat panel tv will not recognize the co-axal cable wire thats pluged into the back of it. Ive chose the all channel search and the digital channel search and neither of them seem to work. The tv always...
There isn't a tv signal on that coaxial cable. The other end of it is not connected to anything with an active signal. For example an indoor antenna, or an outdoor antenna, a cable TV company's active TV source (that you are payin for), or a satallite TV company that you are paying for them to turn on, also TV's do not have a built-in satallite tunner to tune in those sattallite channels, you have to use that company's external tunner box. No tunner box = no channels. Even U-Verse No Tunner Box = No TV.
Jun 02, 2011 | Sanyo Televison & Video
I have an old 23 channel cobra 29. it lights up but does nothing
It is not a dirt issue, the final transmitter is bad. This is caused normaly from a bad antenna or wire going to the antenna. These can be replaced. There is one big on near the back of the radio, 3 prong black transistor connected to a piece of metal (heat sink), unsolder the old one and obtain an exact replacement. (perhaps radio shack or repair shop), solder the new one in. This will sometimes be screwed to the heatsink on the very back of the board connected to the rear of the radio.
Before reconnecting the radio have the antenna checked for damage.
Sep 20, 2009 | Cobra 29 LTD CB Radio
My CDA-9847 will no reconize the SIR-ALP1 tunner.
I am in the same situation.  I have had my sir-alp1 for 4 years and it simply stopped being recognized.  I called Alpine and they said they have no connection to this piece, it is made by "directed electronics" and I need to contact them.  A new one is around $120 whereas this one was 79 on sale in 2004.  I still have he installation guide/owner's manual for it and nowhere inside is there a number to call them.
Mar 08, 2009 | Sirius Satellite Radio Sirius SIR-ALP1...
I am having difficulty when I try to program the VCR to tape a TV show that I am not watching. When I go through the nine steps that are outlined in the manual on pages 24 and 25 the TV will tape for me...
if you are useing a cabel box you need to split your cable before the cable box with a two set coupler and run the second cable line to the VCR input and this should solve your problem. if you want to record the chanels from your cable box and not watch a diffrent chanel you can leave it hooked as is and select the chanel you want to record with your cable box tunner and leave it turned on, set the vcr to record channel 3 or 4 which ever is the channel you leave your tv tunner on and record that way.
Jul 30, 2008 | Televison & Video
Ther is a test you could do is you had the proper equipment, and that would be to inject a know good RF signal into the tunner F connector and chech tha point where the RF/IF is converted to audio and video, to determine if the proble is a bad tuner or not. The equipment is a VA62A Universal Video Analyzer. Its a great piece of equipment for this type of work. another thing you can do is get an RF Modulator from Radio shack and input a video and audio signal in to it and set it to channel 3 and connect the F connector to the TVs F connector. The set the TV to channel 3 you should see the picture and hear sound in channel 3. The VA62A is best because you can set it to emulate all of your channels from 1-87 standard TV and Cable TV. In any event a test needs to be run to see if the tunner is at fault.
Aug 23, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung Flat Screen SDTV Model #TXN3245FPNXXAA
on what you have explain you are to check with cable provider if your tunner was the problem all the channels would be affected try plugging another tv to the same cable and see what it does if you get the same symtoms then it will be from the cable company.if not then you will have to take your tv to a repairman and have it check probably a component in the tunner circuit is bad.or you tunner will need to be replace. good luck
Mar 26, 2007 | Samsung TXN3245FP 32" TV
Kenwood KDC-3028 CD Player Logo
51 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
