Question about HP DeskJet 5652 InkJet Printer
Paper jam my printer hpdeskjet had a paper jam i romoved the paper but it still indicates that their is a paper jam wat shud i do
  • lisaholloway Jul 24, 2008
    I can't get the paper out afraid to remove fearing I'll break it. Please email me back with a solution. Thank You
    email: lisaholloway42@yahoo.com
  • Anonymous Jul 29, 2008
    My machine continues to say there is a paper jam, but nothing is there. Help?
Je veux le pilote pour arriver a utiliser cette imprimante
Posted on May 23, 2008
My printer is showing error as "hardware alarm +1308 +131 --- 000004+0381+1317" wat could be the problem
The hardware error indicated on your printer is indicating that the printer is encountering problems when moving the print head.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
The printer ribbon is not jammed and is located correctly in the printer,
You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the printhead
Nov 18, 2011 | Tally Matrix T2280 Printer
Tip
I followed the steps outlined by nanicool to remove jammed paper from an...
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 24, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Paper Jam.
unplugg power cable from pritner. press adn hold 6 and # key on printer at same time. while holding them down plug it back in at same time. let pritner alligne afdter that. then it shud work fine
Dec 15, 2009 | HP Officejet 6500 Wireless All-in-One...
I have a HPdeskjet 5550 printer. While printing,
Have you tried switching off the printer and then starting after sometime
Dec 09, 2009 | HP DeskJet 5550 InkJet Printer
Hp deskjet 5550 is grabing the paper but paper prints crooked
You may have a paper jam (small paper cut) in the feeder ytry to check it and see if you can clean it...or you may bent the feeder...open it and let me know
Sep 13, 2009 | Office Equipment & Supplies
Hpdeskjet 5550 had paper jam on page 2 of 3 page document, now dead. Turned power off and on, took cartridge out and put back in, nothing working
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 21, 2009 | HP DeskJet 5550 InkJet Printer
Kyocera 3900dn says paper jam in rear but no jam evident
Usually a printer doesn't lie when it indicates a paper jam, if you have checked as thoroughly as possible and no paper can be found. It is possible that the paper just isn't feeding and a printer will sometimes indicate a paper jam when paper doesn't feed. But if this isn't the case and a jam is indicated as soon as you turn the printer on, one of the plastic jam sensing actuators may be broken or hung up.
Aug 05, 2009 | Kyocera FS-3900DN Laser Printer
Paper got stuck in printer
open the back and remove the paper gently. if there's any resistance, take your time. DO NOT attempt to pull it through from the front
Aug 19, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
HP DeskJet 5652 InkJet Printer Logo
70 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
