Question about Alpine PDX-5 Car Amp
PDX-5 is installed on 01 Honda Goldwing. Inputs from OEM radio are routed through adjustable converter to provide pre-amp signal. System connected to 4 speakers & 8" passive Bazooka tube. System plays pristinely at low to medium volume but shuts down when bass is turned up or volume is near capacity. Can you advise?
  • 70 Answers
It sounds like there might not be enough voltage to the amp check that first. If the voltage is lower than 12 volts when you get to that point then you need a stronger battery or a second battery.
Posted on Jul 28, 2010
How to connect a Nakamichi CMS-5 Compact Music System with Harman Kardon BDS 277
There's not a lot of info on the web about the specs and sockets on a Nak CMS-5 or the RE-5 reveiver that's part of the system. So some of this is based on the tiny fragment of information you provided.
The HK BDS277 has no outputs, only inputs. So however you decide to connect, the only way that things will work is if sound signals come from the Nak and go to the HK so that the sound comes from the HK speakers.
If the Nak has processor sockets as you have half suggested, then they act as a break point between the NAK pre-amp which does source selection and the Nak power amp that provides the muscle to drive the Nak speakers. Disconnecting the links from Processor Out/Processor In with interrupt the signal flow. You'll then be able to connect Nak Processor Out to one of the line inputs on the HK.
Any sources already connected to the Nak will then have their signals routed to the HK. The Nak speakers will be silent.
I hope this helps.
Oct 19, 2014 | Nakamichi CMS-5 CD Shelf System
I have Nakamichi CMS-5 and cassette deck DR-5. How i configure it to connect with Harman Kardon BDS 277. In CMS-5 there are 4 Jacks that read Processor, What is the purpose of those jacks. Not a singl
I hope this helps you.
1997 Honda GL 1500 SE Gold Wing radio won't change AM to FM
Hi, Costas for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
GL1500 changing old sound to new GL1500 Information Questions goldwingdocs...
GL1500 AM Reception works FM won pick up any stations
Honda GL1500 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda GoldWing GL1500 1993 Troubleshooting Manual
Honda Goldwing GL1500 SE Owner Manual
Nov 27, 2017 | 1997 Honda GL 1500 SE Gold Wing
1998 goldwing 1500 SE radio & air ride problems
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
No radio or compressor GL1500 Information Questions goldwingdocs com
Tour of my GL1500 Goldwing controls and features
Honda GOLDWING GL1500 Owner Manual
Aug 04, 2012 | 1998 Honda GL 1500 SE Gold Wing
How to remove a 1990 Honda Goldwing GL 1500 factory CB radio?
Hi, George for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
GL1500 CB Radio Removal GL1500 Information Questions goldwingdocs com
GL1500 CB radio install Help
Template service manual $5 donation very cheap
http://www.partsfish.com/page/oem-parts-for-honda
Apr 06, 2017 | 1990 Honda GL 1500 SE Gold Wing
1983 Honda Goldwing GL 1100 radio wiring diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1983 Honda Goldwing GL 1100 radio wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda GoldWing GL1100 Service Manual
Honda Gold Wing GL1100 Owner Manual
Jun 18, 2012 | 1983 Honda GL 1100 Gold Wing
Can I connect a turntable to my Sony mhc nx3av system which I got 12/13 years ago and it is great. Will it be accessed via the MD option? And must I get a turntable with a pre-amp? Thanks in...
YES, you can not only connect a turntable but also a VCR or DVD player or other analog audio sources using either of the top two RCA INPUT jacks on your unit. Now, for a turntable, you will need to buy a pre-amp because typically a turntable provides too low a signal level for most components to handle. These pre-amps cost $35 and up. Most turntables do not provide a pre-amp. Usually an amplifier or receiver will contain the pre-amp and have PHONO inputs specifically for a turntable. So you are correct, you need a pre-amp of some kind. Be sure to select the inputs on your Sony where you connected the turntable when you want to play records. Hope this helps.
Mar 14, 2011 | Audio Players & Recorders
Pre-amp pins were recently removed to add more hardware and now there is no sound when on.The hardware that was inserted into the pre-amp in-puts(red and white) was the Spin It Again program that converts...
It would NOT make sense to connect that Spin It product to the preamp inputs or outputs as this would kill the signal to the amps.
Connect the preamp outputs BACK to the Main inputs as original.
The Spin It thing would probably connect to the tapeTape Out connectors and audio would be routed there to use the Spin It.
Jan 03, 2010 | Harman Kardon HK 3380 Receiver
My radio on my82 honda goldwing dont have sound
(Better1969) is correct. I just bought a 1983 Aspencade and there was no sound to my speakers. The gentleman I bought the bike from supplied new speakers but I quickly ruled that out. There are 3 fuse links behind the left turn signal in the fairing. 1 was a 1 amp, 1 was a 2 amp and the blown fuse was a 5 amp. I didn't have a 5 amp so I put a 2 amp in its place. So far the sound is still working but my FM radio reception is very poor.
May 14, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
Maystar cx475
Ok, I am assuming this is the 600 watt amplifier?
DISCONNECT YOUR BATTERY!!
Supplies needed:
- 8 Gauge power wire (long enough to run from your battery to the amp placement) WITH an inline fuse!!
- Depending on your stereo (if it has amp pre-outs or not) you will either need RCA cables (long enough to reach your amp from your stereo) OR a Line-Out converter AND RCA cables.
- The power lead that connects to your "REMOTE" line on your stereo (long enough to reach from amp to stereo - usually blue)
- A good ground wire ( long enough to reach a metal part of your car from the amp)
STEP 1: Find a spot to run the power wire from your battery - through your firewall and into your car - and then to your amp. (DO NOT CONNECT IT TO ANYTHING YET)
STEP 2: Remove your car stereo and look to see if you have PRE-AMP outs (RCA connectors for an amp on the rear of the unit)
A- if you do, GREAT.. proceed to step 3
B- if you don't.. you will need to get a LINE-OUT CONVERTER - what this does is converts the higher signals from your standard wires on your radio, to RCA style wires to connect to your amp.
B2- you will also want to buy a wiring harness kit for your stereo, unless you want to hack away at your factory wires.. (not recommended) - connect the harness kit to your factory wire harness, wire in your leads for the output converter, and run the other end to your stereo.*
*you will need to know which wires run to the speakers you plan to power with the amplifier
B3 - once the converter is properly connected - proceed to step 3
STEP 3: Plug the RCA cables into the stereo or converter, and run them properly from behind your radio to the amp but DO NOT CONNECT THEM YET.
STEP 4: Connect the REMOTE wire from your stereo to the same wire for your amp . (this enables the amp to turn on/off with your radio.. otherwise.. you will have alot of dead batteries)
STEP 5: re-install your stereo into the car.
STEP 6: Connect the RCA speakers into the INPUTS on your amp
STEP 7: Connect the REMOTE wire to your amp.
STEP 8: Connect the speaker wire from the OUTPUTS on your amp to the speakers you wish to power
STEP 9: Connect the POWER CABLE to the amp PROPERLY
STEP 10: Connect the GROUND CABLE to a metal part of your car (sheet metal, not just a bolt)
STEP 11: Connect the POWER CABLE to the battery cable
STEP 12: Re-connect your Battery
STEP 13: Start your car, and test your radio.
If you have any issues from here.. you need to re-check all of your connections.
Oct 12, 2008 | Car Audio & Video
Alpine PDX-5 Car Amp Logo
200 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
