Question about Sony Cyber-shot DSC-W55 Digital Camera
When i turned on camera shows 'access' then, turn the power off and on again'..WHAT CAN I DO?please reply.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 11, 2011
Not working always show "turn thepower off and on
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Camera if you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Pleaseclick hearto locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Aug 01, 2011 | Sony Cybershot DSCW310 Digital Camera
Turning on the camera.
You can try to remove the battery to allow the circuitry to reset to factory defaults. If that do not work, I would suggest to get repair under manufacturers warranty. Most electronics devices have one year warranty.
Good Luck.
May 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
When I turn the power on, the screen shows "turn
This type of problem can be caused by either a lens issue, or power problem. The following web blogs delineates things you can try to get the camera working again. They say about 50% of the time they can be fixed trying their suggestions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If none of those things helps, try these steps:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the camera still doesn't work, you can take it in to a local repair shop, but get an estimate first. Repair can be high, and justify just going ahead and buying a new one.
Good luck, and hope this helps.
May 27, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
My sony Camera (DSC -W110) is showing "Turn the power off and on again" while switch on the camera,it appers again & again after switching the camera on and off
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
Also tryinitializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available under Setup or Main settingsSub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Mar 21, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
Problems turning on
Please follow these.
1. Remove the memory card.
2. Charged your camera battery fully.
3. Start you camera with out memory card.
Thanks. Waitint for your reply.
Feb 03, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot 7.2 wont let me take photos?
Hello Manea,
                  The main board of your camera get malfunctioning and need to be replaced.This actueally not related to lens.This is main board problem called SY-*** board.For this plz contact any SONY SERVICE CENTRE nearby.
Thanks for using fixya,and dont gorget to rate.
Oct 20, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Camera DSC-W30
Shoot 10-15 times hard thats all..
Jun 08, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
