Question about Canon PIXMA iP1800 InkJet Photo Printer
Paper jam everything was working fine when all of sudden my paper started coming out at an angle-it says paper jam which there isn't any-how do i fix this da--thing? i guess you get what you pay for-i tell my friends to stay away from this kind of printer-one store told me there was nothing you could do-just buy a new printer and the store sold this printer!!!!!!!!!!
  • 2 more comments
  • riandbri Apr 28, 2008
    I have the same issue all of a sudden my paper started to jam and pull to the right side, what can I so I just got this printer.
  • spirilspirit Jun 23, 2008
    i have the same exact problem. with the paper getting jammed on the right side of the printer
  • scoobydoo1 Jun 25, 2008
    Almost the same - I happily printed 10 sheets the next one didn't feed through - didn't get caught or go at an angle, now lights just flashing and it says paper jam - there never was a paper jam and still isn't - there is nothing there ???
  • bengbeng02 Nov 09, 2008
    i have the same problem... cannot print because of paper jammed... but there's no paper jam anyway.. please help me to solve this problem
  • 3 Answers
My printer was also pulling the paper to the right and getting jammed but i have now solved my problem as i found a pen inside that had fell in where the paper goes
so check to see if anything has fallen in
Posted on Nov 14, 2008
Same problem...jams at the right side and all the images are smushed...my solution is buy a new one from walmart, return old one to walmart and try that one...i work there and know that we take everything back, thats where i purchased it in the first place.
Posted on Jul 07, 2008
Daelim Cordi 50cc kic kstart jam.
Best recommendation is take it back ... it is new ... if you mess with it, bye bye warranty. Make em fix the electric start as well. There are unseen issues with this machine.
Jun 27, 2013 | 2011 Daelim Cordi 50
When trying to print getting error Paper Jam in Manual Feeder. There is no Jam...we tap the side of the machine and it prints....any Ideas on what causes this to happen?
There is likely a loose connection going to the manual feed paper sensor.
The printer thinks there's paper in the manual feed, but of course since there isn't any paper there, when it tries to feed the paper in from the manual feed, the next paper sensor is not tripped, so it assumes there is a jam in the manual feed.
Start testing at the manual feed sensor, and work your way back to the board it connects to.
It may be the sensor itself just needs to be cleaned - these sensors are usually optical, and spraying canned air at it will often fix it up.
Also, make sure the lever that trips the sensor isn't sticking after using the manual feed.
Apr 11, 2011 | Samsung SCX4623F Laser All-in-One Printer
Our Brother 7820N all of a sudden started paper jamming. Took everything out and it still jams. What can I do.
Try the link below, if its not working that may be a hardware issue and needs repair: 7820n Paper Jam
Aug 26, 2010 | Brother MFC-7820N Laser Printer
Sharp Z-835 Paper Jams
A few things come to mind;
1) Feed rollers in tray are either worn or dirty
2) Transport tires are dirty
3) Fuser worn
If you've had this for 10 years and have not done much to it besides a toner or drum then I would recommend taking it to a qualified technician.
Oct 06, 2009 | Sharp Office Equipment & Supplies
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
Paper getting stuck
the reason the paper is going in sideways is because one feed roller has more pressure than the other
try cleaning the rollers with alcohol and cotton cloth
If that does not work remove the paper tray t
take your fingers and see if the feed rollers turn freely or turn in only one direction( some rollers are half moon and only turn a half turn)
Just try to make sure that the roller that is not working is in the same position and turns the same as the one that does feed properly
Jan 04, 2009 | Office Equipment & Supplies
Printer
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and it fixed 1st time. seems to of worked for others to, not always 1st time but it seems to reset the sensors or something
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
let me know how you get on, Garty
Apr 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark P6250 paper Jam
Don't know if it's the same problem i had but its maybe worth a try. Canon MP160
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Jan 27, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
82 people viewed this question
old marine
old marine
Corne Viljoen
