Question about Teac DW 28E CD-RW/DVD-ROM Burner
My cd rom tray will not eject and the light is
My cd/dvd rom tray will not eject on my computer and the light is yellow instead of green when I attempt to eject. I also tried to go in a manually eject and it said there was an error in ejecting the F drive. There is currently no disk in the drive. I simply need it to open so that I can install a new printer. No apparent alignment problems noted. Everything was working fine a few days ago. Any suggestions? I have a Pioneer dvd-rwdvrkd08 rs ATA device installed on my computer.
  • 346 Answers
Have you manually tried to eject the disc tray? There's a little hole on there somewhere, stick an unbent paperclip or safety pin in it and push until the tray starts to come out, then pull the tray out with your fingers.
Once you've done that, push the button to allow the tray to automatically retract.
Posted on Jul 22, 2010
How is open the cd room
Bad eject button. If you are running Microsoft Windows, openMy computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
CD-ROM, DVD, or other disc tray not opening. - Computer Hope
www.computerhope.com/issues/ch000214.htm https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=how+to+open+the+cd+rom
Nov 25, 2016 | Computers & Internet
I have an acer aspire x1200-b1601a with a cd/dvd drive that will not open without putting the tip of a knife along the edge and prying it open. the "magic" pinhole is behind the case's cover and cann
CD-ROM, DVD, or other disc tray not opening Locking device or software installed First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive? Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
reference: http://www.computerhope.com/issues/ch001487.htm
Jan 03, 2015 | Acer Computers & Internet
How to open dvd to get disk out
Open Computer in start menu, right click on the DVD/CD rom, Eject. If that fails,Turn off the machine, use a thin instrument to manually pry open the tray. OR remove the DVD/CD rom and disassemble the case. If the DVD or CD has exploded.
Dec 05, 2012 | Gateway Computers & Internet
DVD/CD will not open on my HP Pavllion s7000 what may cause this?
go to computer and try to right click on CD/DVD Rom and then select Eject there.. if this doesnt helps u then u would have to manually release the CD/DVD rom.. just below the tray there is a Small Hole .. use a Needle or any other device that may go in that hole.. try to press on eject button there.. and try to press using needle.. try doing so 3 - 4 times.. there is a latch that needs to be released to open the Tray..
this normally happens if the eject functionality of the tray is not functioning properly.. if ur computer is under warranty .. get the CD/DVD rom replaced.. let me know if this resolved ur issue regards, guru
Apr 20, 2010 | HP Computers & Internet
I cannot open my cd/dvd rom. pls help me to fix it. where i can i find that it is installed on my system .
try going to computer right click on your cd/dvd drive and eject
hope that helps :)
Oct 14, 2009 | Computers & Internet
I cannot get a dvd to play, nor can eject it
I think you have CD RAM and DVD ROM i had also the problem of read dvd but i buy CD/DVD RAM Now my drive is working properly and successfully
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and
DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data
to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Apr 17, 2009 | Dell Inspiron 1200 14.1 XGA LCD...
DVD Door Won't Open
I have this problem with my DVD rom too. I don't know if we have the same ones or not. I took mine apart to try and diagnose the problem, and it turns out that there was this thing inside that wasn't dropping down all the way to allow the tray to slide out, it was staying locked in place.
I was unable to find a cure for this.
However, I found that when I press the button to open the DVD rom, when it fails to open, I give the top of mt computer a slap, and it un-locks the mechanism and the DVD tray slides out properly.
I hope this helps.
Jan 04, 2009 | Acer (91.48R37.002) CD-RW/DVD-ROM (Combo)...
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
Teac DW 28E CD-RW/DVD-ROM Burner Logo
302 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
Computer Links
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
