Question about Ovens
This just happened over night the oven is on but there is a bad gas smell when it is in use. There is a hissing noise too.this oven runs on propane
  • 494 Answers
When the burner is burning, are both sides of the burner lit and is it lit all the way down the burner? If it is and you are still smelling gas you should not use the oven until you have it serviced, so you do not have an explosion. Propane is heavier than air, and will settle in low areas, so smell low by the floor around the oven before you light it to make sure you don't have a leak first. To be safe until then, close the shutoff valve on the gas line at the appliance until you get it looked at and fixed. Douglas
Posted on Jul 22, 2010
Gas odor and turns my pans black
Sometimes theres too much air in the line. A better connection from tank to stove may help, or your running low on propane. Try cleaning the burners with an old toothbrush removing built up sut. Your flame should burn blue, not yellow. Hope it helps!
Sep 16, 2012 | Tappan Ovens
Frigidaire oven won't stay lit
sounds like you have to much propane coming out at one to ignight and flooding it can u adjust the level,of propane that will help unlell u ignighter is a slack one getting old
Sep 14, 2008 | Ovens
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
I have Premier gas stove about 3yrs old. The oven will not work but, you can smell gas and hear a hissing noise. the number off of it is SLK849WPOL. the stove top works and the griddle but not the oven
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Oct 29, 2010 | Ovens
Gas Oven Whistling noise
I HAVE A NEW PROPANE OVEN THAT I CONVERTED TO NATURAL GAS. NOW I GET A WHISTLE WHEN I USE THE OVEN ONLY. DO NOT GET A WHISTLE WHEN I USE THE TOP BURNERS.
Jun 23, 2010 | Maytag Ovens
Gas oven gas not shutting off
sounds like you got some debri in the safty valve, teflon tape or pipe dope. they don't come apart so you will probly have to replace it. sorry! disconect lines and blow out good befor replacing it so it don't happen to the new one
Dec 25, 2009 | Ovens
Oven - Very bad gas smell
Very Dangerous! turn off supply to appliance, supply ventalation and call service tech. If you are very familiar with gas appliances and know what you are doing then you can try to locate the leak using soapy water or leak detector liquid. make sure all flames and other possible sources of ignition have been eliminated. Keep room well ventilated. Spray leack detector on all fittings and look for leaks replace or tighten parts as needed. This responce is asuming you have not blown up already, seriously dangerous situation you have there.
Jan 07, 2009 | Ovens
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
My oven isn't warming up
can you verify the ignitor is working (ie: can you hear it sparking)?
1. If no, and you are absolutely sure there is not a buildup of propane inside the oven (or house for that matter), you can try lighting it with a match. If that works, you need to replace/reposition your ignitor.
2. If yes, do you smell propane after trying to light the oven?
A. If yes, STOP and get it fixed..
B. If no,
1. Check to see that your propane tank isn't empty?
2. Verify the regulator supplying the oven with propane is actually sending gas to the over (might need a repairman for this)
Dec 22, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
F2 error code
Intermittents are a real problem. My first guess: look around for a corroded or damaged electrical feed. Could be electrical noise from that. Not sure what No other possiblities other than a bad panel. I don't know what F2 is.
Dec 06, 2007 | GE JGRS14 Gas Single Oven
Ovens Logo
253 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
