Poor framerate with game- how to improve?
I just recently purchased a HP lappy (dv6815nr) and I need some advice on what would be the best route for me to go;
I was very impressed with the speed of the laptop up until I played World of Warcraft. The frame rate is not so great and actually effects game play SO I was trying to figure out what would be the best thing for me to do to up the frame rate because in-game options/prefs didn't help at all when I cut them all down to the bare minimum. It must be a hardware issue. Now, I was thinking either getting rid of Vista since it's such a Ram hog and putting in XP...OR...since my Ram is expandable to 4gigs-I would expand it. But, I'm at 3gigs right now so would it really make all that much of a difference?
Or if you can think of something even better than the two options I was thinking about- please let me know! (besides buying a better lappy ^__^ )
  • 2 more comments
  • VenomKiss Apr 22, 2008
    Clarification:
    My lappy's got an AMD Turion 64x2 Mobile Tech TL-60
    512kb+512kb L2 cache 2.0ghz just to clarifiy the CPU and then some. I also have 150g hard drive.
    In response to Mark Webber's solution:
    It did help! I could definitely see a difference but not as much as I'd like. :C I KNOW! I'm so finicky. ^__^ The frame rate improved enough that I can move around without lagging a jump off a bridge or anything but it's not as fluid as I'd like to see.
    I'm looking to make it the best it possibly could be for this little lappy. So, what do you think I should do now?
  • VenomKiss Apr 23, 2008
    I went back to BestBuy not only to grab a router but to ask about this issue and I left empty handed.
    One guy said that there should be no reason why my WoW is framey. Another guy said the same exact thing and he also said he tried to stick XP into his lappy just like mine and that HP makes it so it'd nearly impossible to get all the right drivers for it. He said it's just not worth the trouble and it'll never work. I also talked to a Geek Squad guy and he said to try disabling everything on the startup via msconfig. Yeah, did that. And still framey. I was told everything I have should run WoW perfectly.
    Now, the only thing I'm wondering is if maybe I'm just being way too picky about it. I'll have to show someone I know and play WoW for them so they can decide for me. The Geek Squad guy said that if nothing works-it's a hardware problem and the laptop should be replaced. I'll update when my buddy comes to look at it. THANKS FOR ALL THE HELP!
  • VenomKiss Nov 09, 2008
    I actually forgot I had this posting up looking for help with the issue. I'm sorry it's been so long but here's the update:
    -The optimizer failed to do anything for me.
    -My friend that came and looked at my WoW playing turned down a few things directly off the graphics card and then WoW became a bunch more playable. Still not perfect, but still doable. I refuse to play WoW on my lappy because of this though.
    -I do not think that my lagging is due to network connections..reason? Because I can't play Spore on this lappy either and I turn off my wifi to play it. No connection to the net at all. Spore was impossible to play after the cell stage. I think it actually hit 1 frame per minute once. I gave up on that completely.
    I simply cannot game on this laptop and I've exhausted every possibility. I've even contacted HP several times (in hopes of getting a fresh perspective with each employee) and they've all failed to help me. They also refuse to replace my lappy since there's nothing technically wrong with it.
    My experience has led me to believe that if you're not buying a super uber awesome gaming laptop-then don't bother gaming or complaining about f/r. Stick to your higher end desktops otherwise.
    Even so, thanks to everyone for their help~!
  • Richard Roberts May 11, 2010
    what's your CPU?
First of all if you are running vista what ever amount of ram you have in your computer you can just cut that in half the second you bought it. yes its that much of a hog. yes liberate your computer and get rid of vista. getting xp would be a good first step but i dont play WOW but if you can run it on linux by all means that is the best solution. oh and if you just added ram dont expect any change. the main thing that ram contributes too is how fast your computer will run on the internet. more change will be seen with how many windows you have opended or the speed that you can surf the web at. over all solution would to just get rid of vista, maybe add some ram for a slight performance boost,three isnt getting you anywhere, and try running an operating system that has a smaller footprint, linux if it can run WOW or xp. (try using both and only going to xp for gaming thats what i do)
Posted on Apr 01, 2009
  • ravenholm722 Apr 01, 2009
    by the way im fifteen so any possible suggestions on good rpg's without a monthly fee would be a great help thx=)
Sounds like a dual core problem. is it athlon if it is youll need the dual core optimiser. i have same problem unfortunatley i dont think the optimizer works on laptops, bugger!"
Posted on Jun 09, 2008
  • davebro Jun 09, 2008
    CORRECTION you just bought a hp lappy well so did i ditto poor frame rate. try the optimiser and see if you can install it i couldn´t, on mine,
    there is a way you can run the game in single chip mode,
    just GOOGLE that, my lp is in spanish so im still translating.
    best of luck.
  • 472 Answers
Try turning Aero off first. Alot of people have reported no difference, but on laptops in particular I find it does have an impact.
To disable Aero -
  1. Right click the desktop and select Personalise
  2. Click on Theme
  3. In the drop box change it to Windows Classic
It will look boring, but gives back the most horespower to the videocard.
You can change it back the same way, obviously selecting Aero instead.
Let me know how you go =)
Posted on Apr 22, 2008
  • 1 more comment
  • Peter Thompson
    Peter Thompson Apr 22, 2008
    Check you are not running Vista generic drivers as well. You will need to get the drivers from your laptops website not the cards chipset maker nVidia or ATI normally.
    Even the same laptop can have a varied video card in it depending on the spec it's built to.
    Chances are you have a removable video card in there as well and could always get an updated/higher end card then sell off your current one to help cover the costs.
  • Peter Thompson
    The other thing you could do is setup a dual boot system with XP & Vista living together on the one HDD.
    Just make sure you can find all the drivers for XP to make the downgrade possible. Most laptops now have this as an option as a driver pack from the website, though you may have to look around for it.
  • Peter Thompson
    Peter Thompson Apr 28, 2008
    Ok try this if you want to goto XP.
    Ignore the fact they say there are no drivers for a miniute..
    Open Device Manager under Vista.
    Take a note of the exact model numbers for you soundcard, video, lan etc etc.
    Get the manufacturer and the chip version where possible.
    So for lan it could be a Realtek 8029 for eg. So just search for "realtek 8029 xp driver"
    If you search the net, or even goto the manufacturers site for each of the devices you will find XP drivers. The only one you may have problems with is the Video.
    This is meant to come from the laptop manufacturer. Again though, it's normally designed from a reference design, and another driver from another laptop using the same video card will be fine.
It is Blizzards own servers and internet connections. You could have the fastest connection in the world, but if Blizzard is only pumping out 10Kbps to you, thats all you're gonna get.
Now here is a dose of reality that you have to accept. The bottom line with wow is based on the fact that your trying to literally render 80+ people in a large open space. When you crank special effects it adds magical glows, animations onto each of those 80+ people which will beat on ANY card.
I can get 99 FPS staring at a wall in game, but in situations where there are multiple groups of players the frame rate starts to tank. The lack of a difference in performance between the low video and high video settings makes me think it is sync'ed on the network activity. In other words it might not be you. You don’t need to have my computer that I posted above necessarily. In fact getting a new video card might not even help. The key is having globally a decent system to run the game. Even run of the mill desk top computers can run wow decent if you don’t bog the system down with a lot of junk, and lower some of the wow video options.
However, I am going to stick to my first reason for the bad framerate. Its a network sync issue with Blizzard.
MaxCarnage
Posted on Nov 09, 2008
How do i improve my framerate
- Shut down all running updates
- Remove all temporary files from your system
- You must have enough memory on disc that can support your paging memory
- Stop background running applications
- Run Reginout Utility for extreme gaming experience
- Update DX on your system
- Try putting all graphics on low
Nov 20, 2013 | Computers & Internet
I have a hp pavilion dv6815nr. it initially had Vista installed on it. I installed XP on it and got all the drivers to work except the audio. Have tried alot of drivers and nothing seems to work. Any...
The only source of drivers I know is to go to the hp site and put in your computer model on the support link and select XP as the operating system. There is a good chance that this computer was designed for Vista and there are no drivers available.
I would strongly suggest you upgrade to Win 7. You'll like it much more than Vista.
Sep 13, 2011 | HP DV6815NR Pavilion Notebook PC -...
What type of audio card is in my hp dv6815nr. I need to know this so I can install the proper driver for xp jim
Hi jabwolley...
The audio driver below is the one you need according to HP :
Please take time to rate me thumbs up
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-55782-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3686695
Webpage to see you full specs:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01391861&lc=en&cc=us&dlc=en&product=3686695
Video Graphics INVIDIA GeForce Go 7150M Video Graphics INVIDIA GeForce Go 7150M Video Graphics INVIDIA GeForce Go 7150M
Sep 12, 2011 | HP Pavilion dv6815nr Notebook
Why does my hp dv6815nr shutdown unexpectedly? How can I fix this?
The HP DV6815nr has a High end processor I think it sould be around 2.0 ghz.
I run a TL-64 and it is a 2.2 ghz.
The problem is the heat transfer and the best thing you can do is, keep the unit well ventelated.
The 6815 is not very old and should still be within warranty.
HP has had alot of problems with the 6000 and 9000 units, related to heat.
HP has offered a extened 1 year on top of the 1 year warranty. This means, if you purchased this unit 1 1/2 years ago, it still has 6 months of warranty ava.
Do yourself a favor and contact HP customer care and they will send you a Pre-Paid box for shipping back to the factory of repairs, at no cost to you.
The turn around time is 7 working days.
Don't waist time.. !!
Nov 28, 2009 | HP Pavilion dv6815nr Notebook
Can not play a game on my laptop
sorry fella, graphic card in laptop is almost in everycase onboard, therefore not exchangable as in PC-towers, this might cost you a new motherboard or a new lappie!
Jun 17, 2009 | Computers & Internet
I recently purchased a hp 2133 notebook and when I stream videos, be them online or downloaded, it keeps skipping, the picture doesn't flow smoothly. Is there any way to improve the viewing quality of...
No. If your movie was downloaded from the internet the resolution of the film can not be improved. However you can improve the movie reproduction on your system (skip) adding more memory to your system.
Oct 01, 2008 | HP Computers & Internet
Potential Heat Damage?
alot of the games require that a certain video card be used for otimal graphics. your laptops computer could very well have a card that is not up to the challenge of running those games. if you can watch movies and play music and all that other stuff it might just be that. the card you have in your laptop is just not up for the task. my personal opinion and on i am in the process of doing is building a gaming computer. use the laptop for work related things or school related things and the desktop for gaming.
Sep 23, 2008 | HP Pavilion dv6000z Notebook
Call of duty 4 (PC)
Try lowering the in game resolution. This should improve the performance.
Mar 24, 2008 | HP Pavilion dv9000z Notebook
In London, Uk. I have poor reception of channel 5. have got recently a one for all powered aerial. how do I set it up? Model sv-9140-00-002
Your reception would be much improved by using a free to air digital set top box - only about £20. If you are in east London especially near docklands channel 5 reception with a conventional aerial gives a lot of problems. sv-9140-00-002 is an interior aerial booster - I doubt whether this will improve things much. Best solution is a good outside aerial - if you live in flats is there no communal aerial available?
Mar 17, 2008 | Televison & Video
Poor picture quality on a HDTV.
When playing on HDTV's i think you have to have the HD Scart, these are £19.99 in Game and Gamestation. however i have seen them cheaper in PC World i think they where £14.99 (could have been cheaper).
I would try purchasing these connections because the standard connections are only made for normal TV's
Good luck
Mick
Nov 04, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
3,116 people viewed this question
David Payne
David Payne
