Question about E-Machines eMachines Desktop PC
Fan on emachine is making noise. HOw do I fix it?
The fan on emachine, located in rear top right corner, is making noise. HOw do I fix it? It is model T6524.
Thanks,
Travis and Dianne
  • 17,130 Answers
Hi Travis&Dianne, The fan is the cooling fan for the power supply which incidently is a SMPS. These are axial fans working voltage will be specified on the fan body normally 12V DC or can be also higher rating. Now there is a possibility that some dirt or particles could have lodged inside causing the noise. You can use a small thin brush to wipe off, or a good air jet to blown out. These are sealed units and not very expensive. You can also source one from a repair shop as usually when the powerr unit fails the full unit is changed and these go for scrap or E- waste. Your nearest friendly repair shop will be only glad to give you this fan. take the old one to confirm the mountings usually 4screws at corners, replace it making sure the polarity and connector is same or use the old connector. Hope this helps. Good day
Posted on Jul 22, 2010
Sometimes dust accumulates on the fan and cause and imbalance. try blowiing dust out with a can of duster spray, and/or vacuum the vent where the fan exhausts. If all else fails, you can replace the fan by disconnecting it from the motherboard (only try this if your are comfortable working inside a computer). the fan is rated dy the size and rpm/cfm. you can usually order on by entering the fan's model number online.. otherwise find a computer parts store (even Best Buy carries some fans)
40 inch sony bravia making buzzing noises....any suggestions
There are 2 small 1.5" fans that are located on the top right and left sides of the screen. These fans are of the non ball bearing type, so the bearings may be wearing out. You can either replace the fan or add a couple drops of oil to it. Remove the label on the back of the fan and put the oil there, it should quiet down. This will work for a while but eventually the fan will need to be replaced.
Good Luck!
Rich Lilja
Feb 28, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Emachines laptop keep freezing and making loud buzzing noise when i listen to music. please help
The buzzing/grinding noise is probably a bad connection if you are using earphones. Put a couple of drops of rubbing alcohol on some toilet paper and clean the prong for your earphones. Wait a minute and reinsert the plug into the jack. As for the freezing up of the video, you might want to download and install your video drivers for your emachine. Go to the manufacturer's web page to find the right ones. Don't forget to reboot after installations.
Feb 28, 2014 | Acer Genuine Emachines E525 E625 E725...
Fix a fan on a fan oven
Remove plate at rear of oven remove fan blade 3 screws hold fan in place remove bottom screw incompletely slacken top screws. Remove all screws holding rear panel you have bend top right hand corner of rear panel don't worry if pops back when refitted,best to wear gloves, remove fan replace refit in reverse.
Sep 26, 2012 | Cannon 10476G Dual Fuel (Electric and Gas)...
REFRIGERATOR FREEZER IS MAKING A NOISE
Noise inside the Freezer
If your freezer is making a squealing or a little chirping sound, your condenser or evaporator fan is the cause. Open up the freezer door, and the noise usually gets louder. The location of the fan depends on your model freezer. Usually, the fan is located on the rear wall of the freezer. The fan can lose lubrication or become rusty over time. You cannot repair the fan. You must purchase a new one.
Have a nice day : )
Sep 05, 2011 | Refrigerators
Model No.BBL333EB1WW My dryer is not heating what should i do?
check the heating coil which is located inside the dryers' right rear corner. Unplug dryer, open door, remove all screws, pry on top corners with a flat tip screwdriver, disconnect dryer switch, set panel off to the side, lift up on top lid and check to make sure coil is not burnt in half. Hope this helped tim
Sep 05, 2010 | GE DBLR333EE Electric Dryer
Where is the location of the coolant fan switch temperature sensor?
V6 2.8L top right rear of engine. Fan also turns on through A/C pressure switch and coolant temperature sensor, but these should operate independent of the coolant temp switch.
V8 5.0L and 5.7L (Heavy Duty) lower right rear of engine above starter.
Base model V8 uses the coolant sensor (top right of engine) and A/C pressure switches (lower right corner of eng compartment on A/C line to turn on the cooling fan. Fan is energized on all applications through the cooling fan relay.
Mar 03, 2010 | 1989 Chevrolet Camaro
Where is the radiator fan fuse?
under hood fuse/relay box - #13 7.5 AMP fuse, controles Power mirrors, ABS system, Air delivery, Blower motor relay, Rear window defogger relay, Radiator fan relay, Condenser fan relay
#13 is top row of fuses 3rd from left side.
Radiator Fan Relay located right Rear Corner of Engine Compartment
3 black relays in a row, radiator fan relay 1st one on left side of box
Feb 10, 2010 | 1994 Honda Civic
Noise
It will be the external cooling fan that is causing the noise.
Probably worn beaqring or broken fan blade.
Normally, the only solution is to replace the fan motor.
It is located at the top of the oven, usually at the rear, but not in every case.
Please rate my solution.
Thankyou.
Jan 23, 2010 | Zanussi Ovens
Emachine model T3418 problem
make sure the ram is setup correctely or is right ram
Sep 28, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
126 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
