Question about Toshiba SDP93S Portable DVD Player
My portable DVD player just stopped working. I was
My DVD player is a Toshiba SD-P93SWN. I have never had a problem with it before, but it seems it has decided to stop working. I have not dropped it or anything, but it has stopped reading disks even though I had been using it earlier. I don't know how to describe the sound it makes, though when it started making it I knew something was wrong because it kinda sounds like it's stuck. Even though I've looked at it and nothing looks broken or detached.
  • Toshiba Master
  • 17,130 Answers
I understand that your DVD player is playing at times and then plays or skips or jerks. It may beccome worse when the DVD playings a little longer as the heads move out. First you must use a good swab/ and earr bud should be good, to dry polish off the optical lens head- the eye inside the tray. If you get some better performance then wee can be confirmed that your optical heads need a replacement. You will have to open the set find the actual par number and replace with the method required. If not get a help to do this, the new head must be desoldered off the static safety solder bridge, and installed. Hope I could help. Good day
Posted on Jul 22, 2010
Hi When I turn ON my Toshiba SD-P1900 player,with
I brought my dvd player to the Toshiba repair center. To be continued...
Nov 26, 2009 | Toshiba SD-P1900 Portable DVD Player
No valid DVD displays on my Toshiba SD-P1850
Most portable dvd players will not read burned dvd/cds. Please be sure to use originals in your dvd player. If you have a user's manual it should tell you if your player reads CDR's or DVD/RWs
Aug 07, 2009 | GPX PDL805 Portable DVD Player
My toshiba portable dvd player (sd-p1900) won't play discs. We have two, and the other one works, so it's not the disc. When you put a disc in, it doesn't spin, and it says that there is no disc.
i had this same problem, its likely a disconnected ribbon wire off the drive, One I plugged that in it read/spun the disk, now I just need to get the screen to stop being blank white heh. Good luck ^^
Jul 14, 2009 | Toshiba SD-P1900 Portable DVD Player
Unlocking region code
Hi. Same problem re TOSHIBA portable DVD player bought in the USA, model SD-P91SKN. Wonder if anyone found the solution to unlock it to multi-region? Thanks!
Jun 25, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
I have a Toshiba SD-P91S portable DVD player and want region free codes
I Have a Toshiba SD-p91S portable DVD player and I want region Free
Apr 20, 2008 | Televison & Video
No CD sound on Philips DVD/VCR player
I havent seen this model But in the past I have heard this problem arise. It turned out that there was a mute button for the cd only on the remote and there was no indicator to show it. check for a cd mute or go into the cd play menu and check around in there.
Mar 23, 2006 | Philips DVD740VR DVD Player/VCR
Toshiba SDP93S Portable DVD Player Logo
211 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
