Question about HP StorageWorks MSA20 (0808736947138) Hard Drive Array
Regarding the MSA20 Hot Swap Power Supplies, HP Series ESP113A, Does anyone know which pin needs what kind of signal to turn on the 12 volts?
  • 31 Answers
There is no information regards witch pin you need and the signal.
Posted on Aug 15, 2010
Fortron ATX 300GTF wanting 2 power the molex connector on this unit for an external disk drive not linked to a computer.cant get power without plugging in or modding the 20 pin power adaptor.
Most new power supplies can only be turned on via motherboard signal. That is why you have to plug in the 20/24 pin connector from PS to mo bo. When operating yellow wire is 12 volts and red is 5 volts DC. And black is ground.
Mar 07, 2016 | Computers & Internet
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Sep 12, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Mitsubishi 62 inch microdisplay hdtv w/screen w/zy
I have a list of problems common to this series here:
Cause #1
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for
12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check
for an open F9A09 on the Power PCB, if it is open replace F9A09 part #
283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out)
Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if
low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the
Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three
times and then the unit shuts down with a red lamp LED (lamp error). Replace the
Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch
to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light
Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low)
after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB
(ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-
volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light
I would start with #3, checking the 5 volt line and replacing the listed capacitors if needed.
Please be sure to rate this solution. Thanks!
Nov 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mits 527252 ballast
Good Day; I would suspect the ballast, but try these first:
Causes: Cause #1 1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH.
Nov 03, 2008 | Televison & Video
Wd52525 Ballast
Good Day, monkbuist;
TRY THIS:
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH. back.gif
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing yellow
Good Day, davidsonkens;
Try the lamp first; to check try this:
New Lamp turning off after 5 seconds
Apr 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Correct voltage for lamp connection?
(Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 .
Oct 06, 2007 | Mitsubishi WD-62725 62" Rear Projection...
My TV won't turn on. The Green light just keeps on flashing
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Jan 30, 2007 | Mitsubishi WS-73713 73" Rear Projection...
HP StorageWorks MSA20 (0808736947138) Hard Drive Array Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
