Question about Candy CNW136 Front Load Washer/Dryer
Candy Washer Dryer CNWD 136
Hi I have the above washer/drver and although it is still washing/rinsing etc it is making a terrible clunking noise (as if something is loose inside).
Could you tell me what might be wrong. The machine is only 18 months old and has not been used very much and has been well taken care of. also when is spins it make a very load noise.
Will it be expensive to repair or is it something small.
  • Marymartin May 23, 2008
    Regarding my query above. thank you for your answer it was most helpful. After getting an engineer out to look at the machine he said that I have been extremely unlucky and the bearings have gone! He has had to order me a new drum and casing and I'm waiting for him to come back and sort it.
    Champion:
  • 207 Answers
18 months isn't enough for a bearing to die so I guess that perhaps a shock absorber snapped or got disconnected from the drum or machine casing. It is not an expensive part and can be replaced by experienced DIY guy. Perhaps the bolt and nut which hold the shock absorber haven't been tightened properly in factory so in time they got loose completely before falling off. I'm just guessing. Call a repairman to take a look at it and don't use it before it gets repaired.
Posted on Apr 22, 2008
Candy Washer/dryer Stalls
Have you checked the drain hose connection? Make sure the bung is clear in the trap
Aug 07, 2012 | Candy CNW136 Front Load Washer/Dryer
Candy CNW 136 washer dryer not spnning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Candy CNW136 Front Load Washer/Dryer
Washer makes loud clunking noise &so does dryer when moving around, you can turn the basket by hand to make it clunk.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghgf
Sep 03, 2010 | Splendide 2100 Vented Washer-Dryer
Calls error code at end of first rinse
Hi just read your posting.Error 136 means you have''Motor Stall " fault. Now just a couple of questions, has your machine been noisy on spin?does the machine leak water?Please reply with answers and I can help you rectify this fault.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Making a noise when spinning like there a coin inside
heatman101
hdgket
Nov 29, 2009 | Candy CNW136 Front Load Washer/Dryer
Gallery ser. front load makes loud clunking sound in all cycles
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer/dryer problems
If you can locate the filter, remove and clean it.
They are usually found at the bottom front, behind a removable plastic panel.
Plz rate my solution,
Thanks.
Jan 13, 2009 | Candy CNW136 Front Load Washer/Dryer
Water not pumping out
HI
I had a similar problem which I solved by cleaning the filter which had a blockage. It then worked fine. Hope this helps
Jamie B
Aug 14, 2008 | Candy CNW136 Front Load Washer/Dryer
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Candy CNW136 Front Load Washer/Dryer Logo
254 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
