Question about LG Cell Phones
My LG enV VX9900 Cellular Phone is overheated
My phone has been sitting for over a year in my drawer but recently i switched back to it. My phone will not work not unless I put it on the charger and when I do this message pops up ''heat sensor detected high temperatures. Remove battery or move to a cool place'' and when I take it off the charger it says overheated battery powering down for your safety'' please help me do I have to get a new battery?
  • LG Master
  • 17,130 Answers
Definitley your batery had developed reverse polarity and so it will not reain or take in charge. hence the battery will consume more power resulting in this message and it might alsoo be dangerous to keep this on. I would advise you to put in new battery and do the intial charging as required. Keep it on for 8-12 hours of chrage then discharge offf in use fully and rechage again. Repeat this for three time before your battery becomes fully functional. hope this helps. Good day
Posted on Jul 22, 2010
My samsung a257 will not charge. It says paused battery temperature
Consider that it has been sitting for a long time, my educated guess if two chargers have been used and it will not charge you have a bad battery.
Dec 19, 2012 | Samsung Magnet SGH-a257 Cell Phone
Motorola wx345 won't power on
try to boost the battery with external charger or find another battery and try to see if will solve the problem
May 29, 2012 | Cell Phones
Kodak m863 battery is not charging. It has lain unused in a desk drawer for a few years. Have managed to take a couple of photos but now battery will not charge and cannot use on/off button unless...
First of all cheak your charger,it is working or not Then put your camera bettery under the sun light for some time and clean your camera pin where the battery attached,then chaek it
Jun 01, 2011 | Kodak EasyShare M863 Digital Camera
My phone battery died. I plugged it in to charge and now it won't turn back on.
if you did not anything else then connect it on charger and the phone was fully functional before you did this, then try removing the battery and put it back. I don't think that it could be just damaged.
One more thing that it could be... leave the phone on charger for few hours if the phone was lying in a drawer, then it could be that battery was to empty to be able to charge it immediately.
If nothing of this help, try putting working battery in your phone and see if it works. If it works, then you need a new battery, otherwise something else is wrong with the phone.
Kind regards
Goran
Jan 04, 2011 | RIM BlackBerry? Tour 9630 Smartphone
My fisher and parkel dishwasher keeps displaying F1
The best thing to do is turn the power off ,remove the bottom drawer by pushing in the clips on side of the drawer ,just below the round plugs. The clips are attached to runners, push them back to release the drawer and ( after taking out the rack and spray arm) put the drawer on its r.h.side. Mop up the all water in the base, then remove the cover that goes over the back L.h. corner, this will expose the mains/flood switch board ( make sure you dry the roof of the drawer before you take the cover off , or water can drip onto the board .....not a good thing!!!yikes.gif).
To remove the cover, push in the clip in the middle front edge of the cover with a flat blade screwdriverand slide the cover foward a bit, then put the screwdriver under the clip and twist up, the cover should now pull off to the right. Spend a couple of minutes drying the board with a hair dryer and mop up any remaining water ( be careful of the board again). Refit the cover and switch back on ( you shouldn't need to force the cover on, just slide it on from right to left , but you may have to push down the cover just above the clip to get it to lock once it is located correctly). If it doesn't F1 again ,all good, if it does , remove cover and redry, and repeat until it doesn't.
To refit drawer, slide out L.h. rail and sit drawer on it, then lift right side of drawer and slide out other rail and sit other side down. If the rails don't want to slide foward and lock, lift the drawer at the front while sliding the rail fowarduntil the front edge of the rail is just at the clipping gap at the side of the drawer, then make sure the drawer is sitting down firmly on the rails and pull clips foward to lock. If the drawer has been clipped in correctly it will slide in and out nicely, if not , look at the back edge of the drawer when it is fully open to see where it is sitting too high and rectify by refitting the rail on the affected side/sides. By this point if any part of the bottom drawer was broken ,you would have seen it. Also check the top drawer by releasing it and pulling it foward,shine torch in and have a good look.
Hopefully it won't leak again unless ther is a faulty part not visible to the nakedshock.gif eye, check by running one drawer for a couple of minutes, stop the cycle and open the drawer and check the outsides for water ( don't be too worried if you see water in the bottom between the drawers as it will drip from the roof, unless the drain or fill hoses are split ) ,if ok, run the other drawer and check.
Remember, if you get to a point where you don't feel confident with what you doing or you think you might break something, leave it and call a professional to do the job, you may save money in the long run and if you going to expose wires or connections always switch off and unplug before removing the cover, you dont know whats underneathxbones.gif.
Nov 14, 2009 | Dishwashers
It won't come on unless I remove the drawer, put it back in, but then it only runs for a very short time. It's not dehumidifying..Any suggestions for reason/fix/or repair service?
There's a switch activated by you removing it and putting it back in...that switch could be loose or defective...if the Dehumidifier has a Digital screen etc it could be a problem in the circuit board itself . The switch is there to shut off the unit when the pan is full...well the switch would be the first place I look.....and when the unit stops what happens???...the empty tray light comes on ??? It may be possible to install the drawer incorrectly...make sure it sits in properly etc
Oct 30, 2009 | Goldstar DH304 Dehumidifier
COMES ON BUT WON'T STAY ON
On dehumidifiers there are typically two sensors/switches that shut them off:
  1. One for when the drawer is removed; and
  2. One for when the drawer is full.
I would inspect those sensors/switches to see if they are being inadvertantly activated.
Sep 22, 2009 | Goldstar DH304 Dehumidifier
Battery won't charge. Charger works on other Motorola phones.
More than likely the battery is done for...
I myself have so many phones that have batteries that will no longer charge or much less retain a 5 minute charge due to them being on ice for the longest time.
Best bet is to replace the battery with a new/used one.
Mar 15, 2009 | Motorola Mobility RAZR V3
Phone says "out of range"
I'd try pulling the battery on the phone that is out of range and letting it sit for a couple of days. Then plug the battery back in and see if the phone activates. If nothing happens then try putting it back in the charger. My guess is if it's been sitting in the charger the whole time, the battery developed a memory and thinks it's dead.
Mar 11, 2009 | Uniden Cordless Phone
Cell Phones Logo
273 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
