Question about MSI K8N Neo4-F Motherboard
BEST HARD DRIVE FOR THE K8N Neo4 Series MS-7125 (v3.X) ATX Mainbo
What is the best hard drive for the K8N Neo4 Series MS-7125 (v3.X) ATX Mainboard.Have got it all together.But I don't have a clue to what size or anything.For the hard drive.CAN YOU HELP ME?
  • 6,784 Answers
HI. If you are a gamer/producer type. I would go with the Western Digital Veloci Raptor. You will not be disappointed with that monster. Now; If you are a moderate user that dose not crave for power and speed, and want a power saver/green drive, I would go with a Western Digital WD10EARS Caviar Green Hard Drive - 1TB. The green drive will save power and run quite well.
Veloci Raptor
Posted on Jul 22, 2010
How can i install windows 7 on a new sata ******* a msi k8n neo4 motherboard with mainboard cd?
it has nothing to do with the motherboard make sure you format the hdd before you install the OS
Jan 31, 2012 | MSI Computers & Internet
Need a users manual for ms-7125
http://www.msi.com/service/download/manual-4370.html
Select US, or chinese if you'd like.
If this answer helped, please rate it appropriately.
May 04, 2011 | MSI K8N Neo4-F Motherboard
I need drivers fo pci for ms 7125 please send
Hello the download site is here:
http://www.msi.com/service/search/?kw=ms%20%207125&type=product
http://www.msi.com/product/mb/K8N-Neo4-F--PCB-1-0-.html#/?div=Driver&os=All
If the driver not fit select another MB.
First select your windows system.
The drivers you may download needs to be unziped
before you install.
Good luck
Jan 02, 2011 | MSI : 7125-040 (K8N NEO4-F) Socket...
I wanna connect my mainboard to a power but i dont know how
Motherboards can look a bit daunting at first, but they're not really. You question is quite broad, so I'm going to refer you to the manual. First, there is both a version 1 and version 3 motherboard. You'll need to determine which you've got to download the correct manual. Look closely at the board between the YELLOW and WHITE bus slots. You should see some printed text. "MS-7125 V1" or "MS-7125 V3". The V1 or V3 tells you which version you have - either 1 or 3. Download the appropriate manual by clicking the version link: "V1" or "V3"
Unzip and double click the .pdf file inside to open it in Adobe Reader. The manual will display on the screen. Read or print it in its entirety. Pay particular attention to the Hardware Setup chapter (chapter 2 in the V1 manual) and any other part you're not sure about. Rather than me typing all of it in here, you should print out the section (if you haven't printed out the whole manual) and follow it. It goes step by step - one at a time. Skip over parts that are already done, and go to the next.
If you have specific questions about a particular step - ask a question here and I'll answer as best I can for you.
Please rate this reply - thanks!
Dec 02, 2010 | MSI K8N Neo4-F Motherboard
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
Need to know which pins are the start,reset,hard drive,and on. Ms K8n Neo4 motherboard Joe
use a strong magnifying glass and a bright light and look at the pins on the mobo. and your question will be answered.
Nov 09, 2009 | MSI K8N Neo4-F Motherboard
MS-7125 ver1 K8N Neo4 motherboard problem
Do you have the K8N-Neo4 motherboard? MS-7125 is the intern p/n for the K8N
If so, try this address, these are the most recent drivers for the motherboard.
http://global.msi.com.tw/index.php?func=searchresult&keywords=MS-7125&table=download
Hope this is the answer you're looking for
Nov 19, 2008 | MSI K8N Neo4-F Motherboard
Power supply
Ok you will need a gaming computer power supply to run this or it will over power and blow up not literally but it wont work
Jun 02, 2008 | MSI : K8N Neo4 Platinum...
Where can i get the drivers for this mobo, audio , netcard MSI K8N Neo4-F ms-7125 platinum
this is the normal non platinumK8n
http://global.msi.com.tw/index.php?func=proddesc&prod_no=249&maincat_no=1&cat2_no=171
this is the platinum edition
http://global.msi.com.tw/index.php?func=proddesc&prod_no=242&maincat_no=1
by the way...one of the greatest mainboard I ever saw and tested..
I have myself a K9A Platinum..
good luck man...and fixya:)
Feb 08, 2008 | MSI K8N Neo4-F Motherboard
MSI K8N Neo4-F Motherboard Logo
649 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
