Question about LG 24 in. LDS 5811 Built-in Dishwasher
The kenmore dishwasher stopped mid-cycle with water still in it and nothing works. I held the lock-un-lock button still nothing. I am not getting any signs that it will turn on. I checked my House fuse box ( it is fine) could it be the thermal fuse? if so is there any signs to the fuse that would tell me it is out ( like a fuse box in the house? This dishwasher has been nothing but problems since I bought it. Thank you Dierdre
    Top Expert:
  • LG Master
  • 83,850 Answers
Washers do not have a thermal fuse that is dryers. More than likely the washer control panel is defective, have a tech come out and confirm that.
Posted on Jul 10, 2017
  • 641 Answers
SOURCE: Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
bigg t
  • 640 Answers
SOURCE: Diplomat dishwasher blows fuses
I would disconnect the heater then run the unit.If it runs the heater is bad,if the fuse blows again the motor is most likley bad.make sure there are no water leaks.let me know.happy holidays
Posted on Dec 06, 2007
  • 5 Answers
SOURCE: Stopped Working Mid-Cycle
blockage in outlet pipe
Chris
Lg durban
031-7165444
Posted on Feb 02, 2009
jsrock516
  • 5911 Answers
SOURCE: Our Kenmore Dishwasher caught fire.
You may want to contact Sears to see if there was a recall on your model dishwasher. There were problems with the door assemblies on some model dishwashers that were caused by the rinse agent leaking into the wire harness of the door. Over time the rinse agent would corrode the wire insulation causing the units to catch fire in some cases. The fix was a free inner door and wiring harness upgrade kit from the manufacturer. Here is a link you can refer to that may offer some assistance:
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07190.html
Although I did not see your model number listed, you may want to call the Consumer Product Safety Commission number listed at the bottom of the page and report this incident.
I hope this offers some assistance to you.
Posted on Sep 17, 2009
Testimonial: "Gave me just the info I needed."
  • 236 Answers
SOURCE: Kenmore dishwasher... filled up with water and its
Did you check power to the unit? Double check the common and grounds. When servicing I will disconect(unplug from wall) power to the unit. Is it pluged in? Use another outlet(the outlet under the sink may be wired thru a switch for a disposer)even if you need an extension cord. Hope this helps.
Posted on Nov 12, 2009
Why does my washer stop working in the middle of wash cycle and then go dead and no response?
Should get some one to look at it. If there is a hot smell could be a short someplace.
Dec 22, 2016 | Kenmore Washing Machines
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
My Kenmore Elite dishwasher just hums when we start it.Its not starting and no water is filling up
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Aug 09, 2010 | Kenmore Dishwashers
Hi, the 3 sec lock is on and won't turn off, we can't get the dishwasher to start....i tried holding cancel along with the lock but that doesn't seem to work...any thoughts
Ok, this below is worth a shot. Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method. http://frigidaireservicetips.com/pdfs/486_5.pdf
Service and repair manual above. This is what the Engineers use to troubleshoot and repair.
Apr 19, 2010 | Frigidaire GLD2445RF Built-in Dishwasher
We have a Kenmore Ultra Wash Dishwasher, several years old. The lock light went on yesterday and we could not put it on wash or anything. We hit cancel, unplugged the machine, left the door open so it...
There is a key (usually the dry key) that needs to be held for 4 seconds to turn the child lock on or off. If it comes on again try holding this key for 4 seconds.
If it was pressed and held by mistake this could cause the lock to activate. If no one pressed the button and it came on by itself this could be an indication of a touch pad failure in the works. I would need your complete model number to determine what the extent of the repair would be if this touch pad were to fail all the way.
Apr 19, 2010 | Kenmore Dishwashers
Kenmore disposal hums, nothing jammed, everything moves freely, but wont spin. reset button stays tripped & wont catch
Apr 03, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
Works then no power Kenmore 16352
first thought would be a loose connection in the junction box under the dishwasher.
Nov 27, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Kenmore Model 16253 - Stops mid cycle
Sounds to me that the heater is not working, if you have just bought it, it must still be under Guarantee so go back to the supplier.
Nov 18, 2007 | Kenmore 16253 Stainless Steel Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
126 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Marvin
Marvin
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
