Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
The red crt on my 55PW9363/17F keeps flashing and clicking i turn it down till its off and it stops. any suggestions?
  • Philips Master
  • 8,617 Answers
Sounds like the RED CRT Drive board has an issue. Most likely solder issues on the CRT socket on that board. If the board appears fine the CRT itself would be suspect then.
Posted on Jul 22, 2010
Testimonial: "thanks for your help. i took the board off and found two loose solder joints. works great now. thanks again"
Both lights on my older model machine won't stop flashing
Try holding both buttons down while you turn on the machine - hold down till they stop flashing, usually 2 - 5 seconds. This resets the machine to its original factory settings.
Oct 11, 2014 | Nespresso Coffee Makers & Espresso...
There was a power outage, and the red light on the printer keeps flashing but it won't print
Click on start and type services.msc and hit enter. Then scroll down till you see print spooler, right click it and say stop, count to 5 and right click it again and say run.
If this doesn't fix it try turning the power off on the printer and unplugging it and waiting 30 seconds then reverse the steps, plug back in and turn it back on.
Apr 04, 2014 | Dell 1130 Laser Printer
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Ink absorber is full on my Canon MP 160...what do I do?
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Nov 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
MY problem with Sony KP-53S35 53 in. Rear Projection Television. When the TV powers on, the red light blinks until the picture comes on, then the red light blinks go off. I had to wait more than 5 minutes...
the number of flashes of the red indicator lamp points to the possible cause of the delay of the raster or picture, but usually it's an indicator of an emission unbalance between crt(picture tube) guns. the picture will take longer to show up as the emission on either of the picture tubes goes down.
Jul 27, 2009 | Sony KP-53S35 53" Rear Projection...
TV won't turn on, flashing red light
This indicates "vertical stop," meaning that the TV's vertical output circuit is not working. A number of thing can cause this: failure of the vertical output IC or related components; bad solder connections to the vertical output IC (a common problem); power supply trouble keeping the vertical circuit from operating (also a frequent cause). Without having the set available, it's impossible to offer any suggestions for you to attempt repairs beyond looking for bad soldering. Other troubleshooting would require the circuit diagram (often available from the internet), tools and experience working on a live chassis. If you really want to keep the set and don't feel up to self-repair, it might be worth getting an estimate from a shop. These Sonys are nice sets.
Jan 23, 2009 | Sony KV-36FS100 36" TV
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
Pearl 8100
let it charge till the light stop flashing
May 21, 2008 | RIM BlackBerry Pearl 8100
Sony projection big screen
does the led flash when you try to power it up? If so let me know the number of flashes. From your description I would suggest 1 of 2 things happened. (1) The Convergence amp ICs have shorted and blown the 5 amp fuse on the G board, or (2) the red CRT has shorted shutting the set down. Check the fuse and if blown replace the fuse and disconnect the Red CRT PC board from the RED CRT and try powering up the set. If it powers up without shutting down then unplug the set and rehook the RED crt pc board and try again if it shuts down the reds shorted. But if it still wont start with the CRT unhooked or blows the fuse Change the Convergence ICs
Apr 06, 2008 | Sony KP-57XBR10 57" Rear Projection...
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
125 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
