Question about Minolta QMS PagePro 9100 Laser Printer
Starting page when i turn on the printer, automatically it prints a starting page. HOW CAN I DISABLE THAT OPTIONS? Thank you
Its under the Admin Menu under Start Up Options.
Page 160 in the manual.
Good Luck
Posted on Aug 31, 2009
Disable color management
1. Find what you want to print and push print.
2. On the Print page, go to "printer options"
3. Choose to "Black Ink" in the options.
4. This might have to be done every time you print to ensure the colors are not being used every time you print.
Hope this helps----
Jun 19, 2014 | Ricoh SP C430DN Laser Printer
Will not print, I think that it might be two in the system
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel if this fails to fix the problem
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
Apr 12, 2011 | Computers & Internet
Can not print in duplex mode I can not print
Why don't you just print the data on the one side of the page and then simply turn the page over and reinsert it into the paper feeder and then print the next bit of data, therfore you end up with both sides of the page printed without worrying about printer commands that seem to fail.
Feb 12, 2011 | HP cp1700 Color Inkjet Printer
Automatic test page
Work through the menu-items on the printer's LCD screen -- it's an option that you can enable/disable.
Jan 20, 2010 | HP PSC 1410 All-In-One InkJet Printer
Printing Allignment page
Re-install the software and do try to align it when it asks for it again. If it still asks you for the alignment, go to the printer options and try to find a control that will disable printer page alignment.
hope this helps!
-levibit-
Mar 20, 2009 | Office Equipment & Supplies
Printer printing very small
You are using Internet Explorer 7 and it automatically tries to fit the whole page in a sheet of paper.
Go to Page Setup and DISABLE Shrink To Fit
You might want to ENABLE the Background to print the lovely images
Nov 25, 2008 | Office Equipment & Supplies
HP C4200 Printing both sides
Some printers automatically print on both sides of a page (automatic duplex printing); other printers allow you to manually reinsert pages to print the second side (manual duplex printing); and some printers do not support duplex printing at all. To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box.
To find out whether your printer supports duplex printingThe options in the Print dialog box can vary depending on your printer options and configuration.
You can use the following clues to determine whether a specific printer supports duplex printing:
  • Check your printer manual or consult your printer manufacturer.
  • Click the tabs in the Print dialog box and review the options. If options such as print on both sides of the paper, duplex printing, or two-sided printing appear on any of the tabs, the printer probably supports automatic duplex printing.
Notes
  • If you are printing to a combination copy machine and printer, and the copy machine supports two-sided copying, it probably supports automatic duplex printing.
  • If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
To manually set up a printer to print to both sides of a sheet of paperWith some printers, you can use the Manual duplex check box under Printer in the Print dialog box. Word will print all of the pages that appear on one side of the paper and then prompt you to turn the stack over and feed the pages into the printer again.
You can also use the following procedure to set up your printer for manual duplex printing:
  1. On the File menu, click Print.
  2. In the lower-left corner of the Print dialog box, in the Print box, click Odd pages.
  3. Click OK.
  4. After the odd pages are printed, flip the stack of pages over, and then in the Print dialog box, click Even pages.
  5. Click OK.
Note Depending on the printer model, you might have to turn and reorder the pages to print the other side of the stack.
Sep 08, 2008 | Office Equipment & Supplies
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Feb 23, 2008 | HP LaserJet 1010 Printer
HP PSC 1210 All-In-One InkJet print problem
Follow the steps below to enable or disable the cover page option in Microsoft Word.
  1. In Microsoft Word, click File , then Print . The Print window opens.
  2. In the bottom-left of the Print window, click Options . A new Print window opens.
  3. Do one of the following:
    • Select Document Properties to enable cover page printing.
    • De-select (remove the check mark from) Document Properties to disable cover page printing.
  4. Click OK to close that window.
  5. Click OK again to print the document.
Jan 14, 2008 | HP PSC 1210 All-In-One InkJet Printer
Minolta QMS PagePro 9100 Laser Printer Logo
202 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
