Question about Toshiba Televison & Video
Toshiba VCR V-e41A fails to switch on . The fuse is intact. need circuit diagram to repair. please suggest
  • Toshiba Master
  • 12,061 Answers
Http://www.eserviceinfo.com/downloadsm/28259/Toshiba_M-653.html
Above is a VCR Training manual, this is what is used to teach the Engineers how to troubleshoot and repair these types of units.
Usually in these units, it is either the Power Supply is faulty, or, Check the Mode Switch, these are common causes of NO GO. One MUST ALWAYS start at the PSU, as if the Voltages are NOT correct there nothing else can be.
http://www.repairfaq.org/sam/vcrfaq.htm
Above is a DIY troubleshooting and repair website for the VCR.
Posted on Jul 22, 2010
Why does my fuses for my interior lights and my radio and my eletric mirrors blow out
you have a short on the unswitched B positive supply line, could be problem with anything on that supply or a wiring problem. disconnect all the items on that circuit to isolate the cause and replace fuse, if the fuse stays intact reconnect one at time untill fuse fails. that then is the faulty component,if the fuse fails with all disconnected you need to get a wiring diagram and trace the relevant wiring from the fuse that blows and check its integrity, hope this helps. ps you dont say what vehicle this is but the rules above apply to all, but certain vehicles have known issues. cheers.
Sep 17, 2015 | Cars & Trucks
1987 F-350 1 Ton Dump; after breaking a RR turn/brake light housing by backing into a firewood pile while delivering firewood, I have lost front & rear brake & turn signals. My ohm meter indicates...
The fuse #5 next to the flasher should be for the turn signals. Fuse number 1 is for the stop and hazard circuit. Everything goes thru the turn signal switch so the short could be in there. You would need to unplug the turn signal switch to check the circuits with an ohm meter.
The brake and signal circuits are separate until they get to the turn signal switch.
You can register for free at autozone's website and get access to basic repair info and wiring diagrams.
Jan 16, 2014 | Ford F-350 Cars & Trucks
2009 rocker brake lights dont work , fuses good running and turn indicators o.k. any suggestions
Hi Anonymous, this problem is usually cause by the front brake light switch being out of alignment or the button not retracting all the way keeping your brake light on in a closed circuit, depending on your model year. 1996 and earlier models the right handlebar switch housing had to be tight up against the front brake control housing in order for the front brake light switch button to be fully compressed to stop continuity. In 1997 and later models the button was alot shorter and was more of an alignment issue in the switch housing. Rear brake light switches located in the rear brake line TEE can also fail in the closed circuit condition but extremely rare, usually they fail in an open circuit condition where the brake light is not able to activate. For a free wiring diagram please visit the website below. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 03, 2013 | 2009 Harley Davidson FXCWC Rocker C
No picture
If the unit powers at all and you hear some thing from the VCR, and then the unit powers off--problem is in the VCR.
If total dead a fuse is of course possible--If none of these then the TV has a problem in either the High Voltage circuit or the power supply.
To repair or to replace?
May 01, 2012 | Toshiba MV19N2 19 in. TV/VCR Combo
Harley davidson front brake switch
Hi Anonymous, this problem is usually cause by the front brake light switch being out of alignment or the button not retracting all the way keeping your brake light on in a closed circuit, depending on your model year. 1996 and earlier models the right handlebar switch housing had to be tight up against the front brake control housing in order for the front brake light switch button to be fully compressed to stop continuity. In 1997 and later models the button was alot shorter and was more of an alignment issue in the switch housing. Rear brake light switches located in the rear brake line TEE can also fail in the closed circuit condition but extremely rare, usually they fail in an open circuit condition where the brake light is not able to activate. For fuses remove seat and directly behind the battery is a black plastic box. The cover slides up and off revealing the starter relay and the system/fuel pump relay for you injected folks and the various assorted circuit fuses. For a free wiring diagram please visit the website below and good luck.
Feb 02, 2012 | Harley Davidson FXSTB Night Train...
I only see one solid horizontal line on my tv
It lost Vertical sweep either due to open fuse resistor feed the Vertical output circuits, failed vertical/oscillator IC, failed Vertical york (on the neck of the picture tube). Those are what you need to check. This is CRT TV, the repair shop will charge at lest $35 to tell you what I just indicate, to repair it iwll more likely to be in $100 range.
Please leave rating if it helps.
Feb 01, 2011 | Panasonic PV-DM2792 Triple Play 27 in....
Panasonic dmr es30v
Without seeing the actual unit, I would guess that the power supply has failed. These unit have what are called "switch mode" supplies that rely on circuits that oscillate. If a capacitor goes bad, the unit won't oscillate properly, thus no power. These are difficult to track, but are not usually expensive to repair. I would suggest a trip to a service center for a detailed repair estimate. Report the results here.
Dan
Jan 31, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
Fuses blow afer power surge
These are switch mode power supplies and very difficult to repair. If you don't find all the blown components, they just blow up again when you try it. If that model has a separate module for the supply, you can try and order a replacement, but they usually are too expensive.
What model is it? Maybe I have a junker I can take the supply from for you?
Jan 02, 2008 | Toshiba M665 VCR
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
