Own a whirlpool low temp dehumidifier model AD75USTO that collects very little water despite running all day in a basement with humidity level of 70% at about 60 deg F. I opened the case and saw that the coil remains frozen. I also noticed a thermistor mounted on the coil. Possibly this circuit is not working. I sprayed the thermistor with a freeze spray during operation and the compressor didn't do anything?? Help!!
  • ali2222 Apr 24, 2008
    Is it low in freon or is the compressor not cycling OFF? I should've been clearer with my original question, spraying the thermistor with freeze spray should cause the coil thermistor to send a signal to the control board to deice, i.e. switch the compressor OFF, etc. The thermistor varies from 50-80Kohms (measuring after using freeze spray and normal operating temp. Not sure if that's the right values, but at least it responds to temp changes. Bad control board perhaps?
    Genius:
  • 1,073 Answers
The unit is u ndercharged, it has a sealed system leak that needs to be found and repaired then recharged
Posted on Apr 23, 2008
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
New Whirlpool gold dehumidifier last summer. Used since then. It still runs (fan) but no water is being taken from the air. I clean the filters, looked at coils, they are like brand new. I hate to give up,...
Kim, it may simply be a case of the humidity extraction level being set to HIGH. Lower it to 35%. If it's an analog unit (No LED Display) turn the humidity extraction knob to Maximum. More often than not, this will solve the problem. If it doesn't the humidity sensor may need to be replaced.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Whirlpool DEHUMIDIFIER Model - AD70USS1 does fan NOT does not cycle off anymore in the low settings as it should
According to the Owner's Manual for your model, the fan will run continually, if the unit is set in continuous mode or if the unit is in defrost mode. Once the unit senses a rise in the humidity level, the compressor will start up again. Also, a dirty or clogged air filter will cause the fan to run more that it should.
Hope this helps you troubleshoot and solve the problem.
Jun 02, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Fan works but compressor does not kick in, therefore does not collect water. temperature and humidity in basement : same as before
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Apr 15, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My dehumidifier is running but no water is collecting and the bucket usually fills in a few hours, what can be the trouble I cleaned the screen.
heatman101
Feb 15, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a whirlpool dehumidifier 70 pint and the fan runs but no longer collection of water...we have had it about 4 years.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Oct 04, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a Whirlpool Gold dehumidifier that's about 5 years old. The motor sounds and runs just fine, but it's no longer collecting water. Is it fixable?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 02, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
When do you use the dehumidifier?
In areas with poor circulation and humidity over 80%.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
