Question about GE 24 in. Profile PDW8280JSS Built-in Dishwasher
Food is stuck in the bottom wand holes
Small food particles are caught in the holes on the bottom revolving wand, making the dishes on the lower rack dirty. How do I clean these out?
  • 39 Answers
I personally use a metal croquet hook to pull debris out out of mine
Posted on Jul 26, 2010
My Hotpoint dishwasher works fine except that it will no longer wash the dishes in the top rack. It's like the water is not coming up far enough from the bottom to do the job.
There should be an upper spray arm to wash the upper rack, it may be stuck. Look at its position, run the machine a few seconds and see if it moved. The spray nozzles on the arm often get clogged with food particles. the pipe feeding the spray arm has to extend when you pull the rack out and retracts when you push it in. Make sure it works properly and has not disconnected.
Sep 04, 2017 | Hotpoint Dishwashers
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
My LG LDF6920St has not been cleaning very well recently and there was an odor and grease left in the bottom after a wash. I pulled it out and found the Float Assembly pretty clogged and dirty, which I...
1 Scrape and rinse dishes before putting them in your appliance. Small food particles, grease, sauces and bones clog up the system, keeping the dishwasher from properly rinsing your dishes. You don't need to prewash the dishes but be sure to rinse off any solids.
2 Use a toothbrush to clean around the dishwasher door.
Clean around the seal and hinges of the dishwasher. This area often is forgotten and holds a good deal of bacteria and food splash. A tooth- or bottlebrush is the best way to get into the crevices.
3 Clean chunks of food out of the screen and drain at the bottom of your dishwasher, recommended The Family Handyman. If the drain is plugged, the dirty water can't be washed away and ends up back on your dishes. Nut, bean and seafood shells, bits of plastic and small dishes can lodge against the drain, keeping it from doing its job.
4 Unclog the holes in the sprayer arms. If the holes are blocked by food or soap, water cannot freely spray inside the dishwasher to thoroughly clean the dishes. Leftover food on the dishes can make the dishwasher smell.
5 Keep space around your dishes. Overloading a dishwasher keeps it from running efficiently, allowing gunk to build up around the drain and the spray arms.
6 Run your dishwasher as hot as possible to break down food and grease. The recommended temperature is 120 F.
7 Run the dishwasher with vinegar added to neutralize odor. Empty the dishwasher, place a dishwasher-safe cup filled with white vinegar on the top rack, and run a cycle at the hottest setting. If you prefer, use unsweetened lemonade powder or baking soda in place of vinegar.
Jun 21, 2011 | LG LDF6920ST Stainless Steel 24 in....
My dishes are dirty after the wash. The glasses have small particles dried on the inside. They are upside down. How does it do that? Thanks.
Thanks for using FixYa.
An answer for your question about your dishwasher could be that your jets or spray arms are clogged.
1. Please look inside the dishwasher for obvious obstructions and turn the spray arms to make sure they move freely.
2. Now look at the bottom sprayer and at the little holes. If you see food or stuff in any of the holes, use small tweezers to remove.
3. Also look in the bottom area for items which may be blocking the water delivery hole.
4. Finally, look at the top sprayer arm. Using a flashlight, look closely for food or other particles which may be clogging the holes.
Let me know if this helps or if you have questions.
Thanks again for using FixYa,
Apr 03, 2011 | Microwave Ovens
The unit is 6 years old. Dishes on the top rack do not get cleaned. Dishes on the bottom rack are fine.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | KitchenAid Dishwashers
Food gets stuck on dishes especially in the top rack.
There is a waste filter in the bottom under the lower spray arm that needs to be cleaned periodically. If you are not cleaning it, it may be redepositing food particles on your dishes.
remove and clean the filter, and see if that helps.
Nov 21, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
We recently bought a LG 7920ST stainless steel dishwasher. It doesn't properly was the dishes. Leaves food stuck on and doesn't clean the top rack at all. In fact, the glasses are dirtier afterward then...
we had the same problem with a new dishwasher. The repair man told us that the liquid soap would froth too much and not fully rinse out of the system. So the food particles stayed in the trap and wouldn't rinse away. Also the drain hose needs to be looped up to the top of the dishwasher or ran directly down to drain so the wash water doesn't just drain back into the dishwasher. Also check you top rack water jets to see if there are food particles which move into the holes and block the water flow on that level. Hope this helps :-)
Jun 13, 2010 | Dishwashers
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Top rack of dishwasher seems to deposit particles of food on to glasses so not only are they dirty at the end of the cycle, the pieces of food particles are difficult to scrub off them. This happens with...
check the holes on the sprayer for the upper rack, somtimes they get pluged up and the top rack dishes wont get sprayed off. if they are pluged remove them and wash in a sink
Oct 26, 2009 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
GE 24 in. Profile PDW8280JSS Built-in Dishwasher Logo
130 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
