Tempstar furnace manuals for a model NTC trying to fid a wirering diagram for a Tempstar Furnace the main motor model NTC 5125BKB1
5 Suggested Answers
  • 3328 Answers
SOURCE: main burner will not ignite Tempstar(NTC5075BFD1)
try cleaning the pilot oriffice it sounds like the flame is weak
Posted on Jan 17, 2009
SOURCE: tempstar dc90 furnace will not light
Possible solution would be to push the reset button if you haven't already. I have had to do it twice on my dc90 in the last week.
If you look at the glass where you can see the combustion chamber, the glass is oval, follow the long axis of the oval toward the 'top' of the ignition chamber (my unit is laying down, with the blower on the west end and the combustion chamber on the east, as I am facing south). On top of the chamber are two protected spade clips. In between them is the reset. Make sure that the unit is off, press the button, and fire it back up.
Posted on Feb 20, 2009
  • 449 Answers
SOURCE: Tempstar gas furnace fan inducer comes on but
you have something activating ths pressure switch possible blockage in the intake or exhaust
Posted on Sep 10, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: tempstar furnace wont ignite? fan works just wont
your glow rod, is shot...fans will come on but it will not ignite your burners
Posted on Dec 18, 2010
I need wiring diagram for Tempstar furnace model nhgg100ah3
Request the wiring diagram directly from Tempstar.
Dec 31, 2016 | Heating & Cooling
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Just installed a used tempstar nulk075dg03 turned on power and the blower fan wont shut off. turn the thermastat asking for heat the blower motor goes off and the glow comes on the fire lights for a c
its wired up wrong somewhere try to bypass the thermostat wires at the unit and confirm the unit works
then youll know more
other than this i would consult the installation guide and user manual first ...!!! get them from the makers site some makers manuals are not on the general google type search but readily available from the makers site
Dec 21, 2014 | Fasco Intercity Heil / Tempstar Furnace...
What is the model number?
What vent piping? Do you want to reroute inside the furnace or run a vent to outside?
Jan 28, 2014 | Heating & Cooling
I have and older tempstar electric furnace and i have a few questions ccan someone help me
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 15, 2011 | Heating & Cooling
Can I change the fan speed on Tempstar model NULS100BH03 furnace
sure,but why would you want to?you can follow the wireing diagram and switch leads to motor. there may be one thats un used because you don't need it.leave brown alone.colors are usually black,red ornge or blue.white is common,leave it alone.
Jan 11, 2011 | Heating & Cooling
Furnace will just shut off and blow cool air during cycle. Tempstar brand
heatman101
Jan 03, 2011 | Heating & Cooling
I was wondering if there are different fan speeds for my tempstar joist hung furnace and where do i find these
Generally ther are at least three speeds and the wiring should be on the motor if they are varible speed. There should be a wiring diagram on a small plate or sticker on the side of the motor.Hope this helps you. Thanks
Dec 27, 2010 | Heating & Cooling
I need to replace a gas furnace thermocouple on a Tempstar gas furnace. How do I do this? Part # SV9500M2682 on Tempstar model # NUG5100BHB2
HI follow the thermocouple lead back to the gas valve undo the silver nut foloow the lead back to the pilot and undone the nut on thermocouple or it may just pull out , or the burner might have to come out to replace it , if you arenot sure on this then a local gas fitter will do this .
Jan 26, 2010 | Heating & Cooling
Tempstar dc90 dual fuel system seems dead. the
Look for flashing light in bottom door and count flashes after furnace locks out. Read code or flashes with sticker on furnace panels.
Jan 10, 2010 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
315 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
